HaQs
feature request : 1-wire temperature sensor DS18B20 /RS232
Sun Jun 13, 2010 7:11 pm
Please add to ROS support for:
simple 1wire to RS232 adapter:
other sample:
http://www.hoppie.nl/tempsens/
This adapter is very cheap and small size, all elements are easy buy.
Cost < 2 euro.
This adapter can be add to RB411 and any other RB with RS232 / PC to monitor outdoor boxes.
feature request 2: suppor for any cheap USB to RS232 converter then temperature sensor can be connected to usb.
feature request 3: snmp OID to remote monitor connected sensors.
Chupaka
Re: feature request : 1-wire temperature sensor DS18B20 /RS2
Sun Jun 13, 2010 8:32 pm
"MikroTik: Routing the Temperature"...
please write to support@mikrotik.com
but... I don't think it will be implemented in near future...
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
changeip
Mon Jun 14, 2010 12:18 am
you can half way do this now, you just can't use mikrotik to manage the rs232 endpoint. you can setup a virtual serial port that a remote computer can use though. /port remote-access
Colo and Wholesale Bandwidth Available! Sales at SanDiegoBroadband dot com
Chupaka
Mon Jun 14, 2010 2:25 am
I wanted to post about special-login (from this point of view it's the same), but I'm not sure that device uses "data connection"...
changeip
Mon Jun 14, 2010 3:58 am
if its rs232 the '/port remote-access' in raw mode should pass the same data as if plugged into it directly. the special login section seems to be similiar but more like a telnet interface.
Chupaka
Mon Jun 14, 2010 11:28 am
according to the article:
The host machine needs a small circuit to convert the 1-Wire bus to something that can be connected to a standard RS232 connector, although the protocol is not at all RS232.
tgrand
Long time Member
Long time Member
Mon Feb 11, 2013 8:45 pm
Just needs 4 diodes and 1 resistor.
You can talk with these devices through any rs232 interface.
What would be nice, is an api to add monitors to routerOS snmp.
hengst
Re: feature request : 1-wire temperature sensor DS18B20 /RS232
Fri Oct 21, 2016 6:12 pm
any updates on this ? , people did use this by this time ?
i would like to use it kind of same for rs485 devices connected via the serial/usb of a Mikrotik.
jarda
Fri Oct 21, 2016 6:26 pm
Looking like no effort was put to this. You need to look elsewhere.
saaremaa
Thu Oct 27, 2016 7:50 am
CMDR Saaremaa (Gutamaya Sierra Alpha Alpha)
Users browsing this forum: sindy, theonemikrotik and 110 guests
