Ibersystems
RS232 signal across a wireless link
Tue Jun 15, 2010 11:27 am
I need to make a project to pass a RS232 signal of one "relé" (I don't know this in .uk...perhaps relay..) between 2 buildings. This Relé has 2 states.. open or close and i need to put this open/close signal in the remote building of the link. Can I connect it directly to rs232 of a third routerboard?
I'll put a link and I can put more routerboards if I need it.
anyone can help me¿?
Martín
martinruiz at ibersystems.es
Experto en redes WiFi y enlaces WiFi.
Facebook: @Ibersystems
Twitter: @Ibersystems
Certified in Traffic Shaping, Wireless, Internetworking, Routing and User Management.
MTCTCE - MTCWE - MTCINE - MTCUME - MTCRE
netrat
Re: RS232 signal across a wireless link
Tue Jun 15, 2010 3:21 pm
No you'll need a serial over IP solution.
http://www.perle.com/products/Terminal-Server.shtml
Ibersystems
Tue Jun 15, 2010 4:06 pm
Can you explain how is the comunication with this?
If I get an open signal in A-side, it sends X through the wireless link and later in B-Side i get the open signal in the conversor?
How is the configuration of this conversors? I mean.. have IPs, routes?
Thanks,
Martín
gdorm
Tue Jun 15, 2010 4:17 pm
Name name say it all :) Serial Over IP mean it have one IP and route on it and there are different types of how much RS232 ports are on it.
flaguna
Mon Mar 03, 2014 5:12 am
Hola Martin,
Lograste éxito en este proyecto haciéndolo con Mikrotik?
Agradezco comentarios, saludos.
Ibersystems
Mon Mar 03, 2014 10:48 am
Ya no me acuerdo que proyecto era ; ))))))
We used rs232 conversor to pass sensor signals, but not to open a "relé"
Martín
onnoossendrijver
Mon Mar 03, 2014 11:03 am
If it RS232 there is no difference.
RS232 is standardized.
Linux/network engineer: ITIL, LPI1, CCNA R+S, CCNP R+S, JNCIA, JNCIS-SEC
flaguna
Mon Mar 03, 2014 2:58 pm
thanks for your quick response. regards.
flaguna
Mon Mar 03, 2014 3:29 pm
Hello onnoossendrijver.
the idea is to use the RS232 port the Mikrotik, not use RS232/IP gateway add to Mikrotik.
the premise is founded, have one equip that do all=> Wireless RS232 converter and inversely.
It is possible with Mikrotik?
​​​continue to dialogue, thanks, regards.
onnoossendrijver
Mon Mar 03, 2014 4:13 pm
Ah... Ok.. I misunderstood.
I believe this feature was recently added to a beta release and removed one release later because it's was not stable.
So I don't think it's possible unfortunately.
Users browsing this forum: No registered users and 71 guests
