sergejs
MikroTik RouterOS version 5.0beta3 released!
Thu Jun 17, 2010 4:42 pm
What's new in 5.0beta3 (2010-Jun-17 13:46):
*) hotspot - drop hotspot specific tcp connections from non-hotspot clients
already at firewall;
*) lcd - added support for AX89063
*) console - output of '/ping' and '/tool traceroute' commands is more
in line with the rest of the console commands;
*) api - '/ping' and '/tool traceroute' commands are fully functional;
*) console - added 'server' and 'server-port' arguments to '/resolve' command;
*) lcd - show free/total memory in units of million bytes (MB);
*) lcd - added page that shows system identity;
*) sstp - made it work with Windows 7;
*) sstp server - client reconnects did not work;
*) winbox - implemented proper maximize support for inner windows;
*) fix 5&10MHz channel support for 11n cards;
*) added IRQ balancer;
*) enabled PCI MSI on i386 multicore setups;
http://www.mikrotik.com/download/router ... a3.torrent
Important note!
Latest beta release 5.0beta3 have initial support for two features,
1) IRQ balancing - allow IRQ assignation of to a specific CPU
2) PCI MSI support - allows to avoid most situation when several physical interfaces are with same IRQ
Bottom line - with these 2 features you will be able to assign specific physical interface to specific CPU core.
IRQ balancer can be found in "/system resources irq" menu.
ArcticKnyght
Re: MikroTik RouterOS version 5.0beta3 released!
Thu Jun 17, 2010 6:30 pm
Specifying ranges of confederation-peers under bgp-instances is broken in winbox.
/ routing bgp instance set 0 confederation-peers=65510-65520
works from cli but not from winbox.
Also making any change on bgp-instance window in winbox causes configuration entered in cli to be lost.
Xymox
Thu Jun 17, 2010 6:47 pm
OoOo
Cool a new beta...
Loaded on a 450G and 750G.. No new issues... All is well..
avantwireless
Thu Jun 17, 2010 11:00 pm
N connection that was running nice at 20mb/s tcp is now not doing so well. Also a snmp voltage query is now failing on 411AH...
LPby
Thu Jun 17, 2010 11:07 pm
I've upgraded RB750 from v4.10 to v5.0beta3.
Router doesn't boot. How can I restore it???
NetworkPro
Thu Jun 17, 2010 11:34 pm
WOOOOOOOOOOOAAAAAA YEAAAAHHHH !!! THATS THE STUFFFF !!!!!
wiki.mikrotik.com/wiki/NetworkPro_on_Quality_of_Service
Stanislav Hrncir
Fri Jun 18, 2010 9:13 am
Temperature reading via snmp on RB800 still doesnt workning...now i getting "No Such Name" value as respond..
normis
Fri Jun 18, 2010 9:50 am
Take the new RouterOS MIB file and use it with SNMP-walk, you will see the value. There is no name, because there isn't supposed to be a name.
Stanislav Hrncir
Fri Jun 18, 2010 11:31 am
Ooooo Thakns, i´ve installed oid to PRTG and works fine!!!!!
hungwen
Fri Jun 18, 2010 11:51 am
Excuse me, I can't download this file. (http://download.mikrotik.com/all_packag ... 0beta3.zip)
Err Msg:
2010-06-18 16:50:08 Connecting download.mikrotik.com:80
2010-06-18 16:50:08 Connected
2010-06-18 16:50:08 GET /all_packages-mipsbe-5.0beta3.zip HTTP/1.0
2010-06-18 16:50:08 Host: download.mikrotik.com
2010-06-18 16:50:08 Referer: http://www.mikrotik.com/download.html
2010-06-18 16:50:08 User-Agent: Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 6.1; Trident/4.0; SLCC2; .NET CLR 2.0.50727; .NET CLR 3.5.30729; .NET CLR 3.0.30729; Media Center PC 6.0; InfoPath.2; OfficeLiveConnector.1.5; OfficeLivePatch.1.3)
2010-06-18 16:50:08 Accept: */*
2010-06-18 16:50:08 Pragma: no-cache
2010-06-18 16:50:08 Cache-Control: no-cache
2010-06-18 16:50:08 Connection: close
2010-06-18 16:50:08 HTTP/1.0 403 Forbidden
2010-06-18 16:50:08 Content-Type: text/html
2010-06-18 16:50:08 Content-Length: 345
2010-06-18 16:50:08 Date: Fri, 18 Jun 2010 08:50:10 GMT
2010-06-18 16:50:08 Server: lighttpd/1.4.22
2010-06-18 16:50:08 Wait for retry(5S)
normis
Fri Jun 18, 2010 12:07 pm
You are right, we will fix it in a moment.
vacarosie200
Fri Jun 18, 2010 2:22 pm
ros with renos inside??????
take a look at this pic.
the torent was locked by antivirus software....
normis
Fri Jun 18, 2010 2:24 pm
choose better antivirus software :D
schmulke80
Fri Jun 18, 2010 2:51 pm
after upgrading to 5.03beta3 routerboards are not booting.... any idea?
normis
Fri Jun 18, 2010 2:52 pm
which routerboard model you have, and show us what you see on the console output?
schmulke80
Fri Jun 18, 2010 3:00 pm
it was rb600 and rb333. eth link is flapping and nothing on console port,also no "beep" when power is up
NAB
Trainer
Trainer
Fri Jun 18, 2010 5:16 pm
Sounds like exactly the problem I had with a RB230. Completely trashed the boot - no beeps, nothing on the console. Even a netinstall didn't work - it downloaded the files and then just hung. The only way I could resolve it was to take the CF out and do a NetInstall directly to that. Then I had to contact MT and arrange for a new licence since the softID had changed. Having spent a good three hours trying to solve it, I came to the opinion that I was lucky the RB230 boots from CF and that I could remove it. Had it been, say, a RB750, it would have been completely bricked.
NetworkPro
Fri Jun 18, 2010 5:46 pm
I guess its a good thing that jtag unbricking exists ;)
axiang
Fri Jun 18, 2010 8:37 pm
After the collapse of the direct closure of Figure Click winbox
我是中国人
NetworkPro
Fri Jun 18, 2010 10:40 pm
I have just tested that with v5 b 3 the Drivers page is .. a window to another dimension :P an alien dimension :P so it can't be seen. So the ordinary peasent will see it as a funky distortion of the screen. Only those with blue blood will se the aliens waving at him :)
mishaM
Fri Jun 18, 2010 10:41 pm
it cost to install on rb433 and rb600 ? it can die ?
NetworkPro
Fri Jun 18, 2010 11:01 pm
but if you kill the beast you will get xp points :) so do it :P
martini
Sat Jun 19, 2010 1:02 am
dont recommend to update production routers whith intel ethernet that has 4, 8 or 16 queue per port (82575 or 82576) to ROS V5 beta 3
Have some strange issue, but router still work. (supout.rif sent to support)
w0lt
Long time Member
Long time Member
Sat Jun 19, 2010 2:28 am
Seems to work ok on RB433AH, RB433AR, and a RB800.
ROS 5.0beta3, seems to have influenced Winbox a bit, What's with the different styles..change of font and such? Windows7 Influence?
Wish you guys could add a feature to WinBox that would at least allow you to select, or deselect, all the features of any particular window with a single mouse down.
Especially would like to see dialog boxes that had no vertical limit so I could squeeze more into a smaller LCD screen without having to overlay.
MTCNA - 2011
" The Bitterness of Poor Quality Remains Long After the Sweetness of Low Price is Forgotten "
0ldman
Sat Jun 19, 2010 8:49 pm
I need to do further testing, obviously, but my first test of 5 beta 3 shows about a 5dB increase in signal.
0ldman
Sat Jun 19, 2010 9:33 pm
edit: disregard this, something fishy going on here.
Ok, -70s tx, -60s rx, 48mb up, 5.5mb down, 80% CCQ up, less than 20% ccq down on 2.4GHz.
5GHz, -80s tx and rx, 24mb up, 18mb down, 80% CCQ both ways. Dual band rootenna, R52N, single chain.
I can access the tower from my laptop here, this is where I set my CPE's, generally high 70's, low 80's signal, 60-70 ccq typical. This dual band unit generally has worse signal than my standard CPE, however, 2.4GHz RX CCQ is much worse than it was running 4.x or even 5 beta 1 and 2.
AP is RB600, R52H, 12dBi omni running 3.28.
Xymox
Sat Jun 19, 2010 9:44 pm
NetworkPro:
Yes i concur.
I saw it for a second and then winbox closed because I was obviously not worthy to witness other dimensions.
In a very simple SOHO environment on a 750G and 450G 5.0B3 is very stable so far. I have not tried out the Metarouter, but I assume the NTP + Metarouter issue is not addressed yet as its not in the list of fixes for this release.. Not that there is any hurry...
You know,,, completely off topic, well sorta,,,, As a hobby I run a web site that lets you watch the Large Hadron Collider run live, they might find the extra dimensions you mention :)
http://www.lhcportal.com/
andryan
Sun Jun 20, 2010 12:30 am
SSH forwarding still appears to be broken (was also broken in beta2, not sure about beta1) in beta3. I use SSH forwarding to a web server, but the SSH session keeps crashing with "Connection reset by peer".
Xymox
Sun Jun 20, 2010 9:55 pm
Oops....
I cant even get a console to work on a MetaROUTER via Winbox.. I add a new router and the console window opens but I cant type in it..
Also a reminder to anyone doing these betas with routerboards. You should upgrade the boot loader. We are now on 2.7..
http://wiki.mikrotik.com/wiki/Manual:Bootloader_upgrade
schmulke80
Mon Jun 21, 2010 11:20 am
So, i have no chance to restore them?
gbh
Mon Jun 21, 2010 1:51 pm
I have an issue with a 433uah since upgrading to 5.03 (bootloader is also updated) that periodically when logging in by winbox the response comes back as "connection refused"
This can only be rectified after a hard boot or(as the interfaces eventually die as well) after watchdog reboots the router
This did not happen at all on any of the earlier beta releases since 5.0 but has started immediately after upgrade to 5.03...have a supout ready to go
janisk
Mon Jun 21, 2010 4:22 pm
2.26 > 2.7 as usual 26 > 7 mkay?
gbh
Mon Jun 21, 2010 4:35 pm
2.27
oh and btw the routerboard I refer to in my post above is NOT a 433uah it's a RB450
NetworkPro
Mon Jun 21, 2010 4:41 pm
hallelujah askolsun :) Same "connection refused" happened on my RB750 v5b3. The SSH is not working as well, it returns crazy stuff like
connected to: 172.17.xx.xx:22
client version: SSH-2.0-ROSSSH
transport state: 0 --> 1
kex algo: diffie-hellman-group-exchange-sha256,diffie-hellman-group-exchange-sha1,diffie-hellman-group14-sha1,diffie-hellman-group1-sha1
host key algo: ssh-dss
enc algo CS: aes192-cbc,aes128-cbc,aes256-cbc,blowfish-cbc,3des-cbc
enc algo SC: aes192-cbc,aes128-cbc,aes256-cbc,blowfish-cbc,3des-cbc
mac algo CS: hmac-sha1,hmac-md5
mac algo SC: hmac-sha1,hmac-md5
comp algo CS: none
comp algo SC: none
lang CS:
lang SC:
packet follows: 0
agreed on: diffie-hellman-group-exchange-sha256
agreed on: aes192-cbc
agreed on: hmac-sha1
agreed on: none
agreed on: none
signatures are not matching!
code 0x02000003 closing..
closing connection: 172.17.xx.xx:22 (4)
Mac Telnet is also not working.
This box is a BRIDGE + Filter, which still passes traffic + filter filtering, so I will leave for now :P
And P.S. earlier, I had to log in with SSH/MAC Telnet and change WinBox port, because it was also returing Connection Refused, and after I changed it and then changed it back, it started working again. Until this happened - no way in, as described.
And P.S. 2 even earlier, when I first established the Bridge + Filter config, it went to a 100% CPU. I rebooted it and it went down to below 10% even under heavy bridge traffic. Amazing I was thinking to myself, this smalle device can do miracles. Until a miracle happend to it and it got bugged :P
panteraboy
Mon Jun 21, 2010 6:34 pm
Eat too much RAM on RB750 and RB433AH.
RB750, RB433AH, RB2011RM
panteraboy
Mon Jun 21, 2010 7:29 pm
Before I was 15-16MB free RAM
Xymox
Mon Jun 21, 2010 7:32 pm
I believe the problems reported are related to our not having proper alignment of our chi.
https://secure.wikimedia.org/wikipedia/en/wiki/Qi
That, or as previously mentioned by NetworkPro, the transport layer to the other dimensions is a little sketchy because of worm hole instabilities.
I love playing with Beta's ! There is even the remote possibility of bricking a unit ! SO there is even danger involved ! What could be better, the unknown, danger, other dimensions...
warwick09
Mon Jun 21, 2010 9:13 pm
Hmm... I think I'll wait until 5.0beta5 is released.
Xymox
Tue Jun 22, 2010 4:25 am
warwick09: Actually 5.0B3 is pretty stable. Its been running perfectly for me on a RB450G and 750G, aside from the MetaROUTER console window not working, But thats ok, not a big deal for most people.
That said. No one should try beta's unless they are at least reasonably skilled in handling adversity. Like debricking for example. I think many times its easy to forget that a beta is, well, a beta. There is -zero- guarantee it will work correctly. They sure try hard to make it work well, but its not possible to work out all the bugs. Its here so we can help test it and help Mikrotik find things wrong and work out how to make it a stable release.
Most people should wait for a Release Candidate not just a Beta.
But most of you know these things.
warwick09, come on, jump right in. Its fun. Its unknown. Its VERY helpful to Mikrotik.
gbh
Tue Jun 22, 2010 4:44 am
or...you could just make sure you chakra's are all aligned first and you won't have any issues..... 8+)
nz_monkey
Tue Jun 22, 2010 5:22 am
When is the new version with all the wireless changes being released ?
http://thebrotherswisp.com/ | Mikrotik MTCNA, MTCRE, MTCINE | Fortinet NSE7 | Extreme Networks ENA
meth
Tue Jun 22, 2010 12:10 pm
I just upgrade the RB-411AR and i have an issue with userman : fail to add profile or limitation : the Primary key must be unique
normis
Tue Jun 22, 2010 12:11 pm
Which version did you upgrade from? Is your device really appropriate for running User Manager ?
meth
Tue Jun 22, 2010 12:21 pm
it were 4.4 if i remember well, i have 10 users running on userman , i dont now if I need to remove complete the older userman database. I try to this one to upgrade because it have only few users
gbh
Tue Jun 22, 2010 12:59 pm
further on from my above post...I am now seeing "System rebooted because of kernel failure" in the logs and then the unit reboots
8+(
no such issues even remotely similar in the earlier betas on this board.
normis
Tue Jun 22, 2010 1:06 pm
supout.rif -> support@
Insider
Tue Jun 22, 2010 6:49 pm
I wanted to ask first! Nstreme dual under 5B3 sucksssssssssss..
Frequency microwave transvertors, design, development, manufacture
http://Pojitko.cz
mjoksimovic
Tue Jun 22, 2010 8:01 pm
The same problem on some x86 platforms after upgrading from 4.10 to 5.0 beta3. I had to go on the location to reinstal RoS and to downgrade to version 4.10.
"Your chances of success in any undertaking can always be measured by your belief in yourself". - Robert Collier
roadracer96
Forum Veteran
Forum Veteran
Tue Jun 22, 2010 8:10 pm
Ive upgraded about 10 boards to 5.0b3 for testing SSTP and so far, so good... RB1000, RB1100 and amix of RB450G, RB433AH, RB493AH. RB1100 isnt installed yet, though...
roadracer96
Forum Veteran
Forum Veteran
Tue Jun 22, 2010 8:49 pm
The 2 things I have noticed so far. On my RB1000, the CPU will read 100% usage, but I dont think it really is 100%. Im still pulling 10-20mbit when needed over an SSTP/OpenVPN tunnel.
The idle timeout doesnt seem to want to work properly on SSTP. Basically, I need the connection to get destroyed if the client disconnects. Right now, if the client improperly disconnects, the idle timer doesnt count up. Its like it is looking at traffic going into the interface, even though it cant go through the interface. So I have to manually clean-up the old connection before the client can reconnect.
Xymox
Wed Jun 23, 2010 12:23 am
:shock: wow,, dude,,, you installed a beta remotely. :shock:
I guess the only thing more gutsy would be to upgrade a router up on a tower remotely.
Or, upgrade a live production point to multi point setup with beta all around. On towers.
U know.. I dont think its a good idea to install a beta on anything not sitting in the room with you. BUT I do have respect for living dangerously.
0ldman
Wed Jun 23, 2010 1:18 am
I had lightning pop the ethernet port on a 600 170ft up a tower. Just put a wireless hop on the ground and kept going.
I upgraded it a few times, then I had a different board lose the wireless package during an upgrade...
:shock:
That 600 is still running 3.17, and I think it will continue to until I bring it down and replace it.
Now, to keep this on topic, when are we going to get more information on TDMA?
Can we at least find out if it will work with older A/B/G chipsets?
roadracer96
Forum Veteran
Forum Veteran
Wed Jun 23, 2010 2:12 am
And.... I just had SSTP/Ovpn crash again on my RB1000... ongoing problem for 6 months
It has to be something to do with allowing only 1 connection per user and the connections not timing out if the client doesnt tear it down properly. Router continues to function, but wont accept any more PPP connections. PPTP, Ovpn and SSTP.
Im getting pretty tired of this.
gbh
Wed Jun 23, 2010 2:57 am
done, many tx.
J
avantwireless
Thu Jun 24, 2010 8:24 am
5b3 has been a disaster for us. Upgraded x86 system and it started to flap it's backhaul, then crash. Upgraded the AP (RB333) and that started to flap it's backhaul and then crash when trying to winbox into it. Downgraded everything back to 5b2 and all is sane again. It looked like it was related to the ack timing, but when we changed the connection to short headers instead of long.
martini
Thu Jun 24, 2010 2:36 pm
avantwireless - why you upgrade working routers for v5 beta?? test new version on test PC or router
avantwireless
Thu Jun 24, 2010 5:45 pm
Because these kinds of problems don't show up on a bench without real working conditions..
andryan
Fri Jun 25, 2010 5:24 am
can't agree more. people should stop advising others here about not using beta software on production devices. I'm quite sure those who do, do it for a reason. not to mention, most of the time ROS has "hidden" updates which are not specified in the CHANGELOG file.
andryan
Fri Jun 25, 2010 5:33 am
beta3 locks up my RB1000 every now and then requiring power cycle, eventually had to downgrade to beta2.
autosupouts sent to support@, Maris is handling the ticket, no reply yet though.
so far for my needs, beta3 has a broken ssh forwarding, broken counters in /system resources, and unidentified regular lock-ups.
roadracer96
Forum Veteran
Forum Veteran
Fri Jun 25, 2010 6:57 am
What are you using it for? I havent had lockups, but have had all PPP (Ovpn, SSTP, PPTP) stop functioning.
andryan
Fri Jun 25, 2010 7:17 pm
I use IPv6, queue trees, DHCP server, DHCP client, PPPoE client, PPTP client, NTP client, tons of filter/mangle/NAT firewall rules.
mjoksimovic
Fri Jun 25, 2010 7:32 pm
Hahahaha, I agree with you but mistery must be discovered... I installed it on that way because I wanted to try new RoS on my currently working network. However, every lesson must be learned on more difficult way, right?
NetworkPro
Fri Jun 25, 2010 9:37 pm
Hey WTF :)
RB450G
No problems but this one - memory is going up :) uptime 7 days :)
And I couldnt save a supout "cant sart process (6)"
saaremaa
Fri Jun 25, 2010 9:55 pm
Similar problem (memory leaks?) - ROS 5.0beta3:
RB750G - ROS 5.0beta3 - Hangs every 13 hours. Work after reboot.
RB450G - ROS 5.0beta3 - Do not hangs, but the free memory decreases linearly.
CMDR Saaremaa (Gutamaya Sierra Alpha Alpha)
duvi
Fri Jun 25, 2010 11:19 pm
Same here, RB532A.
gbh
Sat Jun 26, 2010 2:23 am
now I'm also getting the "connection refused" when trying to winbox in on my 433uah as well as 450's
NetworkPro
Sat Jun 26, 2010 8:03 am
I think with this unstable Beta 3 we should have a Beta 3 1/2 or a Beta 4 ASAP :)
gbh
Sat Jun 26, 2010 9:21 am
hope so...I'm getting tired of having to climb into the roof at my office to reset my 450's
8+)
saaremaa
Sat Jun 26, 2010 10:09 am
I downgrade my RB750G to ROS 5.0beta2. The problem disappeared. Uptime 14h 12m.
SpectatorCN
Sat Jun 26, 2010 5:18 pm
We have a problem with add or delete rules throw API (PHP) in 5.0beta3 released.
It sometimes work sometimes not.
In 80% API work, otherwise not.
This happened after updating to version 5.0beta3 released.
In good case debug show this:
Connection attempt #1 to 10.*.*.*:8728...
<<< [6] /login
>>> [5/5 bytes read.
>>> [5, 39] !done
>>> [37/37 bytes read.
>>> [37, 1] =ret=f9281e46b87ce5ce068bb81fdbff26ec
<<< [6] /login
<<< [13] =name=user
<<< [44] =response=00e2d17ff801f1138d139e72d93263f7b8
>>> [5/5 bytes read.
>>> [5, 1] !done
Connected...
<<< [31] /ip/firewall/address-list/print
<<< [14] ?list=allow_ip
<<< [20] ?address=10.20.106.5
>>> [5/5 bytes read.
>>> [5, 1] !done
Disconnected...
In bad case debug show this:
<<< [6] /login
>>> [5/5 bytes read.
>>> [5, 39] !done
>>> [37/37 bytes read.
>>> [37, 1] =ret=573744a6028a85260dbd91082539b415
<<< [6] /login
<<< [13] =name=user
<<< [44] =response=003f5f5f781203fc1f8c80001a7118e0aa
>>> [5/5 bytes read.
>>> [5, 1] !done
Connected...
PHP Notice:  Undefined variable: _ in routeros_api.class.php on line 313
PHP Notice:  Undefined variable: receiveddone in routeros_api.class.php on line 323
--- Do not like my English - do not read my messages. ---
Родился в СССР, живу на Украине, говорю по русски, пишу на английском. :)
padiku
Sat Jun 26, 2010 7:35 pm
I have tested RouterOS V5Beta3 to my server router with bonding 2 Gigabit ethernet Broadcom for outside traffic (BGP to local internet exchange)) and Intel pci-express with 4 Gigabit ethernet for inside traffic (3 servers). the router stable for 24 hours. but unfortunately incoming and outgoing traffic stuck in 1 Gbps only. I see IRQ and CPU is assigned automatically. I'm still confused why traffic only stuck in 1 Gbps, it should be 2 Gbps... ??
please help me...
my server spec :
- HP DL140G3
- Processor 2 x Intel Xeon Quadcore
- Memory 2GB
- Resource/CPU Load 25%-30%
NetworkPro
Sat Jun 26, 2010 8:06 pm
I am willing to do what I can to assist you, friend. I am asking for a WinBox login sent to my Skype.
padiku
Sat Jun 26, 2010 8:55 pm
may I know suspect source of problem ?
is it from my intel pci quad gigabit ? because I tried to do bandwidth test between servers (in 3 of 4 pci port) only get 1 Gbps maximum.
NetworkPro
Sat Jun 26, 2010 9:05 pm
If you do a bw test between two servers, their ports are 1gbps each so the test will show 1gbps per direction. Depending on the test and CPU usage while it runs. Are you comparing results with another version of RouterOS or another OS or hardware?
roadracer96
Forum Veteran
Forum Veteran
Sat Jun 26, 2010 9:46 pm
FYI, I had the memory leak thing show up on 433AHs and 450Gs and 493AHs, but after upgrading firmware to 2.27, it seems to have gone away. Have about 20 routers running on 5.0b3 in production running SSTP and they seem to be stable. Some for over a week now.
NetworkPro
Sat Jun 26, 2010 10:24 pm
I always upgrade the bootloaders (a.k.a. "firmware" @ /system routerboard upgrade). Memory leak exists.
Xymox
Sun Jun 27, 2010 1:07 am
I have a procedure for beta's.
Upgrade the router. Upgrade the bootloader.
Reset the config to default. I like the idea of clearing the NV settings to what the defaults should be for the new version.
Copy/paste a script with my settings. This script ONLY has the changes I need.
Reboot.
I then try to not touch config and just see how it works.
BTW im on 9 days of uptime on a 450G and 5.0B3. So far no issues to report. Well memory use might be going up.
NetworkPro
Sun Jun 27, 2010 2:24 am
I try to test upgrading as well, if it works OK. So I just upgrade and watch what happens.
roadracer96
Forum Veteran
Forum Veteran
Sun Jun 27, 2010 6:52 am
Reboot.
Somewhat agreed. Except that it should work on an upgrade... Lets say even 10% of routers in production get upgraded, that is going to cast a long shadow over the amount of routers sold NEW with said version.
roadracer96
Forum Veteran
Forum Veteran
Sun Jun 27, 2010 6:58 am
Im changing my tune on the memory leak. My RB1000 is showing it... Didnt notice it at first. Also checked a couple RB4xxs. My guess is the bootloader SLOWED it.
Xymox
Sun Jun 27, 2010 7:13 am
Well the reason for my "procedure" was because I had upgraded and downgraded and sidewaysgraded and played with my config until it was raw and eventually I ended up with a 450G and 750G that were psychotic. The settings all looked fine in Winbox but all sorts of things were not working correctly, it was hanging and src-nat was not working at all.. The lights were on but Norman Bates was at home.
I reset to defaults and loaded the script and everything was fine.
So from that point on, I decided on a testing method I would use for all my beta testing.
This is really different then for the vast majority of installs where you config once and then upgrade infrequently. I think for those of us who fiddle with our config a lot and upgrade and swap versions around its good to start from a clean slate now and then. I just do it every time. I did a lot of the Open-WRT beta's and you ALWAYS start from a clean slate or you can brick a router. So its just built into my psyche to start from a clean NVRam or you might brick something.
Absolutely its important to know if a normal upgrade path works. So maybe to test this, it would be good practice to start with the base version, reset to defaults, paste in a script, and THEN upgrade. This would eliminate any possibility that some previous corruption of the base version corrupts the upgrade. So start with a known clean base version before upgrading.
Side note... When down grading be careful of the bootloader. You will need to downgrade that too. You do that by upgrading to the downgraded version :) hehehe...
Xymox
Sun Jun 27, 2010 7:16 am
Im seeing memory usage increases on my 450G and 750G
HUGE increase over 9 days. I was going to run out of ram on my 450G !
Wow... a memory leak..
gbh
Sun Jun 27, 2010 9:17 am
Ok, couldn't take it anymore... Downgraded back to beta 2 and now all my problems have gone away.
Will wait for the next release
padiku
Sun Jun 27, 2010 10:12 am
Sorry, I mean 1 Gbps test result is total bandwidth for 3 ports. so each port utilization not more than 300/400 Mbps. that test using RouterOS version5 beta3. previously I'm using version 4.4. the reason why I upgrade to version 5beta3 because my bandwidth utilization stuck in 1 Gbps.
anybody ever test intel pci-e with quad port gigabit and get result more than 1 Gbps ??
w0lt
Long time Member
Long time Member
Sun Jun 27, 2010 6:12 pm
Using 5.0beta3, I can't seem to monitor an wireless interface with Torch, downgraded to 4.10 and it's ok. Bug?
-tp
MTCNA - 2011
normis
Mon Jun 28, 2010 10:47 am
any news about SSTP? everything working correctly so far? how about Windows 7 clients to your SSTP server? Also work fine?
SpectatorCN
Tue Jun 29, 2010 5:29 pm
Downgraded to 4.10 and it's work ok. But have old problem with many not dropped session.
roadracer96
Forum Veteran
Forum Veteran
Tue Jun 29, 2010 7:19 pm
Cant say for sure yet. Have about 20 SSTP connections, but all OVPN/SSTP bombs randomly which you said is because of OVPN.. But im not upgrading any more because of the memory leak.
NumLock
Tue Jun 29, 2010 9:15 pm
RIP feature is not available in beta 5.0 beta3?
rpress
Tue Jun 29, 2010 11:54 pm
The memory leak requires a reboot every 8 hours on my RB750. MT said they fixed it for beta4.
SSTP is working with IPv4 and beta3. I wish SSTP would listen on IPv6 but it does not. :( I only have one IP at home and I use HTTPS. That means I can not use SSTP at all. Win7 only supports port 443. If it worked with IPv6 then I have plenty of IPs.
normis
Wed Jun 30, 2010 7:55 am
Will see if we can do something about that
nz_monkey
Wed Jun 30, 2010 9:06 am
5.0beta4 appears to be on the Mikrotik website.
Users browsing this forum: Bing [Bot] and 129 guests
