PietRetief
Ping in script problem
Thu Jun 17, 2010 10:50 pm
I recently loaded a script on a routerboard running ROS 5.0 beta3 and the output is not what I expected.
The following is an extract of the scrip to illustrate the problem:
:local otherside 172.18.254.134;
:local latency [ping $otherside interval=20ms count=100];
:log info ("Ping timeouts ".(100 - $latency));
On a rb running ros 3.30 it works perfectly, yet on the new rb running ros 5.0 b3 it does not. I double checked by running the ping in winbox, and it is correct. The log output should contain the amount of pings that timed out, yet it prints 100 (meaning the result of the ping command was 0). Please see attached images.
Did the syntax or usage of the ping command change?
Regards,
Pieter.
Chupaka
Re: Ping in script problem
Fri Jun 18, 2010 5:05 pm
What's new in 5.0beta3 (2010-Jun-17 13:46):
*) console - output of '/ping' and '/tool traceroute' commands is more
    in line with the rest of the console commands;
try
in Terminal and see the result
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
PietRetief
Fri Jun 18, 2010 7:07 pm
Hi Chupaka, thanks for the reply. I see the two outputs differ. Now the question is, how do I get the original result as this new method breaks my current scripts :lol:
Chupaka
Fri Jun 18, 2010 7:40 pm
unfortunately, I have not installed beta3 yet, so I can't see actual output, and you don't want to post it =)
PietRetief
Fri Jun 18, 2010 7:53 pm
Hi, sorry, I did not realise you do not have beta3 available.
Here is the output from beta3:
[admin@rb433ah] > ping 172.18.254.134 interval=500ms  count=10
HOST                                    SIZE  TTL TIME  STATUS
172.18.254.134                          56    64  241ms
172.18.254.134                          56    64  220ms
172.18.254.134                          56    64  280ms
172.18.254.134                          56    64  330ms
172.18.254.134                          56    64  228ms
172.18.254.134                          56    64  310ms
172.18.254.134                          56    64  276ms
172.18.254.134                          56    64  191ms
172.18.254.134                          56    64  243ms
    sent=10 received=10 packet-loss=0% min-rtt=191ms avg-rtt=262ms
   max-rtt=330ms
and this is from Ros3.30:
[admin@rb433] > ping 172.18.18.254 interval=20ms count=10
172.18.18.254 64 byte ping: ttl=64 time=5 ms
172.18.18.254 ping timeout
172.18.18.254 64 byte ping: ttl=64 time=3 ms
172.18.18.254 64 byte ping: ttl=64 time=11 ms
172.18.18.254 64 byte ping: ttl=64 time=14 ms
172.18.18.254 64 byte ping: ttl=64 time=4 ms
10 packets transmitted, 8 packets received, 20% packet loss
round-trip min/avg/max = 3/6.1/14 ms
Here is the output for a :put command:
Ros5.0beta3
[admin@rb433ah] > :put [ping 172.18.254.134 interval=500ms  count=10
172.18.254.134                          56    64  371ms
172.18.254.134                          56    64  411ms
172.18.254.134                          56    64  207ms
172.18.254.134                          56    64  127ms
172.18.254.134                          56    64  221ms
172.18.254.134                          56    64  147ms
172.18.254.134                          56    64  401ms
172.18.254.134                          56    64  227ms
172.18.254.134                          56    64  267ms
    sent=10 received=10 packet-loss=0% min-rtt=127ms avg-rtt=259ms
   max-rtt=411ms
Ros3.30
[admin@rb433] > :put [ping 172.18.18.254 interval=20ms count=10]
172.18.18.254 64 byte ping: ttl=64 time=6 ms
172.18.18.254 64 byte ping: ttl=64 time=12 ms
172.18.18.254 64 byte ping: ttl=64 time=2 ms
10 packets transmitted, 9 packets received, 10% packet loss
round-trip min/avg/max = 2/6.0/12 ms
9
Looks like the last line on ros3.30 contains the variable number I am looking for, but for beta3 it is a blank line. Any ideas? My Mikrotik scripting is very... basic :D
Chupaka
Fri Jun 18, 2010 9:10 pm
hmmm... I can't find a way to get the result of ping command in beta3... sounds like a lack of feature =) because "sent=10 received=10 packet-loss=0% <...>" seems like API output, but you cannot get it via CLI :( will wait for beta4 =)
PietRetief
Fri Jun 18, 2010 9:18 pm
Thanks for the help Chupaka.
PietRetief
Fri Jun 25, 2010 10:10 pm
Can anyone from the Mikrotik staff please confirm if this problem will be addressed in beta4?
Or if there is a way to get this script to work on beta3?
Thanks :D
Chupaka
Fri Jun 25, 2010 10:24 pm
please write to support@ to be sure =)
PietRetief
Fri Jun 25, 2010 10:28 pm
I did :)
Sadly no reply yet, but I am sure they are busy with it. Just wanted to get some confirmation.
roadracer96
Forum Veteran
Forum Veteran
Sat Jul 24, 2010 1:42 am
Im tyring something similar.
This works from the CLI:
:foreach i in=[/ppp active find where radius=no] do={ :if ([/ping count=1 [/ppp active get $i address]]!=1) do={ /ppp active remove $i } }
But not in a script. The ping command returns the number of successful pings as a result on the CLI, but not in a script. Is that intended?
Chupaka
Sat Jul 24, 2010 2:32 am
beta5 is here, you may check it =)
roadracer96
Forum Veteran
Forum Veteran
Sat Jul 24, 2010 4:42 am
Been running beta5 since 9am EST on 4 routers... :D
Chupaka
Sat Jul 24, 2010 12:34 pm
and the problem you described is still here? then write to support@ =)
roadracer96
Forum Veteran
Forum Veteran
Sat Jul 24, 2010 11:33 pm
I will. I never tried doing that particular function until yesterday. Im assuming it did work because I saw failover scripts that used it in that way... :D
PietRetief
Tue Aug 17, 2010 7:20 pm
Good day. I have been busy on a different project for a while now, and have only recently had time to look at this ping script again.
I loaded Ros5 beta 6 and the ping script is still not working.
I will send a mail to support as well, I just wanted to keep this thread updated too.
Please see attached image for the results.
Best regards :)
PietRetief
Sun Oct 10, 2010 12:36 pm
Hi, I checked RC2, the problem is still there. :(
dssmiktik
Forum Veteran
Forum Veteran
Sun Oct 10, 2010 5:30 pm
In v5.0rc1 it seems to work fine for me, both in terminal and scripts.
It may be that it accepts properties more like other commands (ex. /ping address=x.x.x.x ....)
This worked for me:
# Should output 5
:local p [/ping address=127.0.0.1 count=5 interval 1s]
:put $p
Output: 5
# Should output 0
:local p [/ping address=255.254.254.254 count=5 interval 1s]
:put $p
Output: 0
Doug
PietRetief
Sun Oct 10, 2010 5:45 pm
Hi dssmiktik, thanks for the reply.
I checked and yes, it looks like the ping works when you run the script via the terminal. But if you run that script by running clicking the icon on winbox or via the scheduler it does not work.
Please see attached screenshot:
1 - ran via terminal, output is correct.
2 - ran via winbox, output is wrong.
3 - i use Log to output the variable because I do not intend to run the script via console every 5 minutes on 100 routers.
P.S. This ping script is a small part of a much larger script.
dssmiktik
Forum Veteran
Forum Veteran
Sun Oct 10, 2010 9:01 pm
Sorry, I missed the part about only running it via winbox (not terminal).
I'm getting very weird results as well. When I run via terminal, the terminal output and log both show correct values. When I run via winbox, the log shows an empty entry, completely blank. Also, when I run :execute "/system script run <scriptname>", completely blank log entries are created.
Doug
dssmiktik
Forum Veteran
Forum Veteran
Mon Oct 11, 2010 9:57 am
I emailed support and this was their response:
Right now we are working on more serious bugfixes. We will fix ping as soon as possible.
v5.0RC1 = v5.0beta7 IMO
Doug
PietRetief
Tue Oct 12, 2010 2:33 pm
Yup, exactly the same response I got.
I can understand that they have more important problems, it is just a pity that this one part happens to be broken :(
Lets hope for a fix in RC3 :D
dominicbatty
Tue Oct 26, 2010 2:36 pm
I cannot believe this is still broken in RC2, I logged this originally in Beta4. My entire fail over scripting is based on the use of this /ping command which only works under the schedule once on the very first call to it, after which fails to work.
I appreciate that they are working on "more serious issues" but are they trying to fix topics utilised by 2% of the user base because they are complex but are simple functions like ping considered unimportant.
You would think if the fix the ping were simple they would just put it right to get all these people off their backs moaning about it not working.
roadracer96
Forum Veteran
Forum Veteran
Wed Oct 27, 2010 4:55 am
Where is RC2? Id love to see if SSTP is fixed...
roadracer96
Forum Veteran
Forum Veteran
Wed Oct 27, 2010 5:27 am
Found it. :D
mangust
Wed Oct 27, 2010 5:26 pm
Found it. :D
Found what?
There is no "offical" RC2. Is'n it?
roadracer96
Forum Veteran
Forum Veteran
Wed Oct 27, 2010 6:48 pm
Its in the same place they put stuff before official release.
Didnt fix SSTP memory leak. Blew threw 200+mb ram in 9 hours on my RB1000 and clients were unable to connect.
Didnt fix 100% cpu usage either.
NetworkPro
Wed Oct 27, 2010 11:39 pm
OMFG this problem is still annoying @ pre-RC2 @ 22nd Oct.
the ping in script does not return the value :(
My beautiful script from v3 is ruined now, its not working. I coded that for a whole week !!! GRRRR!!!
wiki.mikrotik.com/wiki/NetworkPro_on_Quality_of_Service
NetworkPro
Thu Oct 28, 2010 9:14 am
This should be fixed in final v5 as per an e-mail from support.
dssmiktik
Forum Veteran
Forum Veteran
Thu Oct 28, 2010 9:49 pm
I emailed support about this as well. It is not a new feature, it is an existing feature that got broke.
Broken features are more urgent then anything else in my opinion. If a feature breaks, wait to release until all existing features still work as intended.
Doug
NetworkPro
Thu Oct 28, 2010 10:33 pm
NV2 is more important tan scripting. Wireless PtP links rarely use scripts.
PietRetief
Thu Oct 28, 2010 10:35 pm
I am sad to say, the problem is still present in RC2 (2010-Oct-27 16:20)
Lets hope they fix it before 5.0 final.
PietRetief
Does NV2 give you dynamic QoS limits on fluctuating links due to change in ccq, noise, etc?
NetworkPro
Fri Oct 29, 2010 1:02 am
I hope so :)
roadracer96
Forum Veteran
Forum Veteran
Mon Nov 01, 2010 6:08 pm
New features should always be secondary to fixing broken features. ALWAYS.
NetworkPro
Mon Nov 01, 2010 6:28 pm
Hey MikroTik guys, how do you make these decisions?
Chupaka
Mon Nov 01, 2010 7:50 pm
simply: higher priority for bigger customers
mrz
Tue Nov 02, 2010 8:44 am
Fixed, wait for next version.
PietRetief
Tue Nov 02, 2010 4:55 pm
Thanks mrz, I cannot wait to get my claws on RC4 then :D
NetworkPro
Tue Nov 02, 2010 7:09 pm
Me too!!
dssmiktik
Forum Veteran
Forum Veteran
Tue Nov 02, 2010 8:59 pm
Me three!
Doug
Chupaka
Wed Nov 03, 2010 12:08 am
me - zero, I use v5 in production =)
mazari
Mon Nov 08, 2010 6:30 pm
I got a RB493 that originally came with the RouterOS 3 and then I decided to upgrade it to 4.11. I am working on a script where I also need to ping a public IP (e.g. google) but the command won't work from the script (Winbox), however, it does when I execute the command from the terminal. A couple of days ago I read this post and PietRetief mentioned that his script worked on RouterOS 3.30 but not in RouterOS 5 and today I downgraded from RouterOS 4.11 to RouterOS 3.30 and I still got the same problem. I even tried to run PietRetief's script and it works from the terminal but no from the Winbox. Any idea why I am not able to run PietRetief's script from Winbox using RouterOS 3.30? Any idea on when is RC4 coming out?
NetworkPro
Mon Nov 08, 2010 6:42 pm
My ping is working with pre-RC4 for mipsbe from 05 Nov. I upgraded a lot of routers with this version.
mazari
Mon Nov 08, 2010 8:30 pm
I will upgrade my RB493 to RouterOS5rc3 and see what happens ...
mazari
Mon Nov 08, 2010 9:09 pm
What do you mean by pre RC4? I tried RC3 and it didn't work
NetworkPro
Tue Nov 09, 2010 4:05 am
It's the RC4 test version that is shared under /share/ .. .npk as per usual. NPK Package time (seen from WinBox) is 5th Nov.
I can't recommend anyone trying this version since its very unofficial. If the router broke, who would be to blame?
Chupaka
Tue Nov 09, 2010 2:59 pm
maybe, script doesn't have necessary permissions?..
mazari
Tue Nov 09, 2010 3:56 pm
NetwokPro, I am sorry for being such a noob but I can't find where this unofficial version is (/share/). Can you be more specific where I can find it?. I don't mind trying it on my router because I am using this router to learn more about Mikrotik and I am not using it on a real application. However, if the router breaks you know who I'll blame :lol:
mazari
Tue Nov 09, 2010 4:00 pm
I am the administrator, however, how can I check this?
mrz
Tue Nov 09, 2010 4:01 pm
RC4 is not available for public, and even if you get RC4 it will not solve your ping problem because v4 and v3 did not have problem that was solved in RC4. As Chupaka mentioned it might be script permission problem (check if you have all necessary policies selected), or some error in script itself.
Copper
Tue Nov 09, 2010 4:03 pm
Link to pre- versions you may get by sending request to support@ if you explain why you want this.
Here on the forum, you will not get the link to testing build.
NetworkPro
Tue Nov 09, 2010 4:21 pm
Hey guys, been testin a bit here, this script
under ver. pre-RC4 of 05th Nov.
:log info ([/ping 127.0.0.1 count=4])
seems to be able to persistently (~10+ times in a row) write the result in log with the permissions of Read and Test :)
Under v5 when you doubleclick the script, it opens for editing + you can select the permissions above the script itself.
P.S. I also just tested the same script again, with full permission set, in the official RC3 and it writes the number in log only the first time. Every consecutive attempt writes an empty log entry.
I hope this helps clarify the issue.
mazari
Tue Nov 09, 2010 4:29 pm
HI NetworkPro
Thanks for your help. I will try 3.30 again with the permissions to see if I am able to ping because I don't have access to pre RC4
mazari
Tue Nov 09, 2010 5:34 pm
You are right Chupaka, I tried 3.30 again with the right permissions and it worked...Thanks!!!!
PietRetief
Thu Dec 09, 2010 7:27 pm
Hi guys, I tested on Ros5rc5 and the ping command works when used in a script again!
Thank you very very much! :D :D :D
Users browsing this forum: Google [Bot] and 117 guests
