MUM Europe 2020
FIPTech
Router OS 5.0beta3 - cannot connect winbox through IP
Sat Jun 19, 2010 1:38 am
Router OS 5.0beta3 : i couldn't connect winbox through IP. This problem has never happenned with beta2.
I was able to connect through MAC address.
After reboot, i can connect again to Winbox through IP address.
martini
Re: Router OS 5.0beta3 - cannot connect winbox through IP
Sat Jun 19, 2010 10:12 am
check you firewall or route, winbox to IP on v 5.3 works fine like all other version, tested on windows and linux
posix
Tue Jul 13, 2010 11:18 am
There is definitely a bug in winbox service in 5.0beta3!
After a day or two I can no longer connect with winbox. I have to ssh into the router, /ip service 6 disable and /ip service 6 enable and then I can connect with winbox again.
Chupaka
Tue Jul 13, 2010 7:12 pm
try beta4
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
Users browsing this forum: cbrown, mjezierski and 52 guests
