I have followed the following tutorial:
http://www.mikrotik.com/documentation/m ... /L2TP.html
and while I can ping over the tunnel from each router, I can't access either side from behind either router. It is like it isn't routing between the physical and VPN interface. My traceroutes go to the router then stop there. The best example I have is this diagram:
https://acrobat.com/#d=xd1pUokCPfrfWoT2WREjYw
Where the statically routed IP 74.168.1.68 can be pinged from 74.168.1.170, but any pings to 74.168.1.68 from any other location all die at 74.168.1.170. The same is true for the private networks behind both 74.168.1.170 and 209.191.192.45 neither are reachable from the other network even though static routes exist that point the networks to the 10.2.1.x (other side of the tunnel's IP). Just the fact that I can ping from within either end point to either the statically routed IP, or the far end network should demonstrate that the static routes are built correctly.
I'm all out of ideas and scratching a hole in my head.
Miles
