omidh
keepalive-timeout
Fri Jun 25, 2010 7:30 pm
hi
i use MT as ADSL BRAS and the problem is that most users suddenly disconnected from BRAS without any reason.
i think it should be keepalive-timeout.
what is the best value of "keepalive-timeout" for pppoe clients. and is it good to set this value to 0 ?
how about "one-session-per-host" ?
can we use "one-session-per-host" in order to prevent pppoe clients to connect more than once?
thanks.
omidh
Re: keepalive-timeout
Sat Jun 26, 2010 10:46 am
please help :(
Chupaka
Sat Jun 26, 2010 5:52 pm
without any reason.
and what's in Log?
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
omidh
Sat Jun 26, 2010 6:47 pm
it's realy hard to trace the log because there are so many transaction at the moment.
here is the log
Jun/26/2010 15:30:11 pppoe,ppp,info,account er7712 logged out, 13999 3837760 25365835 20107 24951
Jun/26/2010 15:30:12 pppoe,ppp,info <pppoe-er7712>: terminating... - disconnected
Jun/26/2010 15:30:12 pppoe,ppp,info <pppoe-er7712>: disconnected
Jun/26/2010 15:30:11 pppoe,ppp,info,account er4672 logged out, 11489 7887362 37315433 80206 32967
Jun/26/2010 15:30:12 pppoe,ppp,info <pppoe-er4672>: terminating... - peer is not responding
Jun/26/2010 15:30:12 pppoe,ppp,info <pppoe-er4672>: disconnected
any idea about "keepalive-timeout" and "one-session-per-host" ?
omidh
Sun Jun 27, 2010 9:31 am
dear Chupaka haven't you seen such this problem before?
Chupaka
Sun Jun 27, 2010 11:10 pm
nope, I don't use PPPoE...
you may try to increase keepalive-timeout. if it won't help - try to set it to zero (or make it big) and enable one-session-per-host, but I'm not sure whether it works with non-local authorization. also, check for errors on your ethernet interface
Users browsing this forum: eworm, Kindis, Laxity, nescafe2002, plisken, protoontje and 200 guests
