civilman
stream video from internet - bandwidth problem
Sat Jun 26, 2010 1:02 am
Hello community!
I have such configuration:
internet optic 30Mbit <-> dlink l2 sw <-> mikrotik x86 (quad core - good server) <-> dlink l2 sw (same) <-> dlink optical l2 sw <-> my optic channel 100mbit <-> zyxes router <-> ethernet to my computer.
Mikrotik do NAT, FW, PPPoE, simple & queue tree, radius, ... Processor's usage like 1-3%.
My computer, based on source/dest IP mangle & queue have 20M limit-at value and internet link used at rate like 5-9mbit (at the moment of the testing)
/queue tree print
name="Up" parent=global-in limit-at=20M priority=8 max-limit=30M burst-limit=0 burst-threshold=0 burst-time=0s
name="Down" parent=global-out limit-at=29M priority=8 max-limit=29M burst-limit=0 burst-threshold=0 burst-time=0s
(Upload rule) name="10.1.2.25-up" parent=Up packet-mark=2103 limit-at=7M queue=default priority=5 max-limit=7M burst-limit=0 burst-threshold=0 burst-time=0s
(Download rule) name="10.1.2.25" parent=Down packet-mark=2103 limit-at=20M queue=default priority=5 max-limit=20M burst-limit=0 burst-threshold=0 burst-time=0s
/ip firewall mangle print
chain=postrouting action=mark-packet new-packet-mark=2103 passthrough=yes dst-address=10.1.2.25
chain=prerouting action=mark-packet new-packet-mark=2103 passthrough=yes src-address=10.1.2.25
My problem that i can download p2p torrent files with good speed (at 1.5-2.3M/sec, like around 20Mbits) BUT if i try to see some video from youtube i have bad bandwidth.
Please advice what to see? What to check?
I am also find interesting thing: when i test bandwidth with http://www.speedtest.net site i got different result's at download (form 5 o 50Mbit's - i don't have 50Mbit link!!) and stable 6.5Mbit upload as you can see at queue tree... Why so? dunno...
Edit post: I try to test Btest server - i got exactly what i have at shaper - 19.6M/6.5M... but when i change Global rule Down to 150M and my shaper value to 100M i got 24-25M/6.5M.... why i can't pass 100M traffic?!
Dmitriy
Chupaka
Re: stream video from internet - bandwidth problem
Sat Jun 26, 2010 3:45 am
try to increase lengths of your queues
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
civilman
Sat Jun 26, 2010 12:43 pm
Morning!
I try 50 -> 200 packets at default and ethernet-default change - did not help...
civilman
Mon Jun 28, 2010 8:19 pm
Up to topic!
Any advice for my problem?
Main problem that stream video from internet goes with delay... may be some wrong config of the mikrotik shaper?
PrvtPilot
Mon Jun 28, 2010 8:33 pm
Had that same problem with my system. It was all about the queues. I tried what you did increasing the packets and that actually made things worse.
The solution for me was to implement a different queue type, here are the settings:
Name: clientqueue (change to what ever you want)
Kind: sfq
Perturb: 5
Allot: 1514
Once I switched to that queue type my problem went away. Try setting a client or two to that queue type first and see what happens.
Hope this helps.
Dean
bafh
Mon Jun 28, 2010 8:39 pm
Wrong network builder.
civilman
Mon Jun 28, 2010 9:56 pm
PrvtPilot - thx i try...
bafh - instead of stupid comments say something useful.
bafh
Mon Jun 28, 2010 10:03 pm
Pay someone who knows how to.
Chupaka
Mon Jun 28, 2010 11:06 pm
bafh, is it ad of you, or you advertize someone else? :D
civilman
Mon Jun 28, 2010 11:23 pm
hey! hey!
help me ;) i can't understand... I have better "traceroute" to youtube than my friends, have better speed ~20M, but my friends with bad trace & ping & low bandwidth have no problem at all... movie load faster than you can see it, but in my case i have some lags with video... ;(
I try sqf type of queue - that did not help... situation the same.
btw torrents work FINE... at 20M rate.
HELP! what to see? what to change? need some logs/traces/config files?
civilman
Wed Jun 30, 2010 8:21 am
Problem solved!
The solution is to change mode of Ethernet on fiber convertors to 100mbit full-duplex, instead of auto mode.
Thx to all! Shaper work fine!
Chupaka
Fri Jul 02, 2010 2:48 pm
hmmm... were there some errors on your ethernet interface?..
civilman
Fri Jul 02, 2010 2:54 pm
errors was at:
Uplink internet <-> ethernet port (100mbit full duplex manual) <-> ethernet2optic converter (in mode automatic)
Users browsing this forum: Google [Bot] and 66 guests
