bokad
Mikrotik Equivelent Of Cisco "switchport trunk native vlan x
Sat Jun 26, 2010 6:19 pm
Is there a mikrotik command to use on an ethernet port that has the same effect as the cisco command below?
"switchport trunk native vlan x"
Basically to set which VLAN will have the untagged frames on that interface?
Chupaka
Re: Mikrotik Equivelent Of Cisco "switchport trunk native vl
Sat Jun 26, 2010 6:50 pm
all untagged packets come to etherN. if you want to receive/send tagged packets, create VLAN interface on that ethernet
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
sandov63
Mon Oct 22, 2012 8:53 am
i have a similar question, but what happend if i connect a port with trunk from a cisco to mikrotik with a native vlan x ? do they negociate well? cisco needs the two ports o both side of the trunk have the same native vlan, mk does not have this command
excuseme by my poor english
Cuando la ignorancia se impone, la razon cordialmente cede el paso.
tomaskir
Trainer
Trainer
Mon Oct 22, 2012 9:01 am
Just as Chupaka said.
All untagged frames come to the ether[x] interface. If you want to receive tagged frames, create a vlan interface for that vlan. Any frames coming to this vlan interface, will be replied to on this interface.
It works, just as any device would using the .1Q standard.
Unimus - configuration management, automation and backup solution
Mass Config Push, network-wide RouterOS upgrades, and more!
Users browsing this forum: Bing [Bot], kangpaidjo, Renfrew and 96 guests
