pedja
Long time Member
Long time Member
URL filtering possible?
Mon Aug 29, 2005 6:13 am
Is it possible to set MT to filter all http connections to url's containing some keyword?
changeip
Mon Aug 29, 2005 6:55 am
you can enter any plain text into the CONTENT field on a firewall rule and it will block any packets containing that. Make sure you specify port 80 and that it's not going to interfere with other traffic and you should be good. We use it to block UserAgents in the HTTP headers all the time.
Sam
maroon
Mon Aug 29, 2005 2:30 pm
try using Sufcontrol on a seperate machine
it works too and it's goin will with me
if you need more information about setting it up with Mikrotik ...contact me
Regards,
lastguru
Mon Aug 29, 2005 3:03 pm
if filtering is just allowing/disallowing, then URL keywords (substrings) may examined by transparent web proxy on routeros
bholler
Trainer
Trainer
Sat Sep 10, 2005 11:52 pm
hello marron, what is thename ofthe surfcontrol u r using and is it free ?
i will appreciate the url of the particular one u r using... thanks.
maroon
Mon Sep 12, 2005 6:37 pm
hey listen it's a surfcontrol itself ...
try googling surfcontrol or superscout ... and try using the windows based version...
the configuration is somehow complicated .. but if u need any help.. i'm ready
good luck
Users browsing this forum: infabo and 138 guests
