YazzY
SSH and FTP dies after a while
Tue Jul 13, 2010 8:17 pm
Hi.
On beta4 on x86 I've issues with both FTP and SSH daemons dying after a while. They need to be re-enabled to work again.
normis
Re: SSH and FTP dies after a while
Wed Jul 14, 2010 9:15 am
re-enabled how?
make supout.rif file when they are "not working" please.
mangust
Wed Jul 14, 2010 10:20 am
re-enabled how?
Confirm. I have support.rif Should I attach it here ? :)
[xxx] > ip service print
# NAME PORT ADDRESS CERTIFICATE
0 telnet 23 0.0.0.0/0
1 X ftp 21 0.0.0.0/0
2 X www 80 0.0.0.0/0
3 ssh 22 0.0.0.0/0
4 X www-ssl 443 0.0.0.0/0 none
5 X api 8728 0.0.0.0/0
6 winbox 8291 0.0.0.0/0
[xxx>
c:\Apps\nmap-4.20>nmap -p 22 xxx.xxx.xxx.xxxx
22/tcp closed ssh
c:\Apps\nmap-4.20>nmap -p 23 xxx.xxx.xxx.xxx
23/tcp open telnet
Plus ....
It's not possible to make ssh from MT...
"died with signal 11 on Tue Jul 6 09:29:08 2010"
normis
Wed Jul 14, 2010 10:22 am
send to support please
YazzY
Wed Jul 14, 2010 11:10 am
re-enabled how?
Re-enable as in disable and enable the service again (works with just i.e /ip service enable ssh ).
mangust
Wed Jul 14, 2010 11:11 am
Ticket#2010071466000159
normis
Wed Jul 14, 2010 11:18 am
OK, we will check. Yazzy, please also send us a supout.rif file when the SSH/FTP is not working.
YazzY
Thu Jul 15, 2010 12:35 pm
Ok, I sent supout.rif for two routers. Both experiencing the same problem.
Vaelen
Sat Jul 17, 2010 9:55 am
I can confirm this as well.
RB532A running beta 4
will send supout when it dies again
Ryan Carter
Network Engineer C4ISR
MTCNA, MTCRE, MTCWE, MTCTCE
CCNA
dreadmaul
Wed Aug 25, 2010 4:01 am
Confirm STILL bug in Beta 6 on RB-450G
got scared when I couldn't log into remote site... luckily I have a tunnel that accepted a telnet session. <whew>...
Users browsing this forum: Baidu [Spider], evince, Kindis, sindy, wispmikrotik, Znevna and 155 guests
