MUM Europe 2020
econst
POE Switches
Thu Jul 22, 2010 10:02 am
This has nothing to do with ROS, but just wanted to know. Can a POE switch provide different voltage levels? If so, which model? Thank.
sonny
Re: POE Switches
Thu Jul 22, 2010 1:26 pm
Hi, you can use this: www.restlesspowerbox.com
contact me out of list ks (at) cn24(dot)net if interrested
sonny
Karl Sonnleitner
Senior Wireless-Expert
Restlesspowerbox - managed powersupply for Routerboards
econst
Re: POE Switches
Thu Jul 22, 2010 7:28 pm
Thanks for the response. I was more thinking in line of a swich that you can set the voltage level at each port, or block of ports. For example on a 12 port switch, I could set ports 1 to 4 for 18V, ports 5 to 8 for 24V and ports 9 to 12 for 48VDC. Is anything like that available? Can I modify a switch to make it a POE switch by just putting the appropriate pins on the port at the voltage levels required. Pls advise.
willtech
Re: POE Switches
Thu Jul 22, 2010 8:31 pm
Here is a link to a POE switch that can do 0VDC, 12VDC, 24VDC, and finally 48VDC.
http://www.inscapedata.com/lps.htm
Take Care
econst
Re: POE Switches
Thu Jul 22, 2010 10:26 pm
Willtech, it is something like that that I am looking for, just with at least 12 ports, and preferably rack mountable/interior use. Thanks.
Feklar
Re: POE Switches
Fri Jul 23, 2010 6:55 pm
If a switch says that it supports PoE then it uses the 802.3af standard. So no there is no way to specify non standard PoE on switches as far as I know unless the are specifically built for it, I.E. Cisco having backwards compatibility with their own old style PoE.
Users browsing this forum: aeiouy, Bing [Bot] and 70 guests
