mars
RouterOs 5b5 memory leak
Wed Jul 28, 2010 7:44 pm
Hi
we installed 5beta5 on x86 machine and it has a very bad memory leak
it takes 1 hour 10 minutes to drain 750meg ram then the computer reboots
why is this problem not fixed it was known in beta 4
normis
Re: RouterOs 5b5 memory leak
Wed Jul 28, 2010 7:45 pm
make supout.rif, send to support
roadracer96
Forum Veteran
Forum Veteran
Thu Jul 29, 2010 6:02 am
Ive been sending supouts.. Memory leak has persisted in b4 and b5. SSTP restarts. Today, my RB1000 rebooted itself..
martini
Thu Jul 29, 2010 11:26 am
router uptime 4 days, v5beta5 - no memory leak, traffic 400-800 Mbit, all works fine exept queue tree ))
mars
Thu Jul 29, 2010 1:46 pm
do you use a x86 machine?
martini
Thu Jul 29, 2010 3:51 pm
yes, installed on 5 x86 routers
mars
Thu Jul 29, 2010 4:28 pm
can the queue be the cause of this memory leak
the memory counts down from 750 meg and when it gets to 12 meg the x86 machine reboots and must be switched on and off at the power to start again
we have now installed b5 on a rb433 and will see what happens
mars
Fri Jul 30, 2010 12:01 pm
We have installed RouterOS 5beta5 on an RB433 and ran is for 24 hours with no sign of a memory leak. Therefore it seems to only be an issue in the x86 version.
roadracer96
Forum Veteran
Forum Veteran
Fri Jul 30, 2010 3:00 pm
Its not only on x86. I have it on about 100 RB4xx boxes and no sign of memory leak. On my RB1000 though, it is there. But I am running SSTP SERVER on the RB1000. The RB4xxs are clients.
mars
Sun Aug 01, 2010 4:28 pm
how is it possible that b3 , b4 , b5 all have memory leaks and the x86 is the worst
now it is leaking on our 433 as well but much slower
how are you supose to test the beta when the memory leakes out in 1hour and everything locks up
mangust
Tue Aug 03, 2010 10:50 am
Do not panic. May be it's because of some specific package that you use. In any case ... I think that if you create a ticket and send suppout.rif then MT will have a chance to check what kind of package (process) use a lot of memory. Without suppout.rif they can't detect anything.
Users browsing this forum: No registered users and 160 guests
