singh
Disconnecting a user
Mon Aug 09, 2010 10:27 pm
Hi
I am using MikroTik router OS hotspot feature to connect clients. I also have users who connect on VLAns.
Basically to disconnect any hotspot user, I simply disable his/her username.
To disconnect VLAN users, I disable their IPs.
Now the tricky part is that on one VLAN, I have five users sharing one address using o D-Link router.
Is there a way I can disconnect any of these users without disabling the five?
Ibersystems
Re: Disconnecting a user
Mon Aug 09, 2010 10:52 pm
Use a switch instead of a router or a rb750 to make another hotspot there.. ; ) i think your network isn't well designed.. Usually a router is one unique costumer.. You can use a switch or a bridge to fix this, then each user must have a unique ip.
Martín
martinruiz at ibersystems.es
Experto en redes WiFi y enlaces WiFi.
Facebook: @Ibersystems
Twitter: @Ibersystems
Certified in Traffic Shaping, Wireless, Internetworking, Routing and User Management.
MTCTCE - MTCWE - MTCINE - MTCUME - MTCRE
adrianatkins
Long time Member
Long time Member
Tue Aug 10, 2010 12:11 am
Go to their house and steal their Laptop.
Works every time.
This is a popular choice - see Ebay.
Don't forget to give me at least a tenner a month, every month
Ibersystems
Tue Aug 10, 2010 12:27 am
xDDD
Martín
adrianatkins
Long time Member
Long time Member
Tue Aug 10, 2010 12:31 am
I bought one once off ebay.es
Admin username was 'Martin', password 'Ruiz' ........ :lol:
It had a load of Advanced Traffic Shaping, Advanced Wireless and User Management info on it.
Also quite a lot of unusual WiFi-related porn ... the things you can do with an antenna, even the square ones !
Don't Panic. I had to wipe it an install linux, so you're safe.
Chupaka
Tue Aug 17, 2010 10:15 pm
Adrian, give me that grass %)
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
Users browsing this forum: Bing [Bot], MSN [Bot] and 96 guests
