Madrox
How have 2 pppoe router on the client side? whitout tunnels
Fri Aug 27, 2010 12:39 pm
Hello, when we install to or clients we use statios psubrigde, and then a wirless router.
How can we do it, when we have to routers? iknow i just can make tunnel, but this will be messi at the end. and wds it out?
Is it som other ways?
mrz
Re: How have 2 pppoe router on the client side? whitout tunn
Fri Aug 27, 2010 12:41 pm
station pseudowire allows only one tunnel to be established.
Madrox
Sat Aug 28, 2010 12:20 am
yes iknow that, but if i set it on station mode, and brigde wlan whit eth1 og eth2 it will not work?. so is it any other whys do do it, whitout creating wds? or manual make eoip tunnels to every clients that have more then one pppoe tunnel?
mrz
Mon Aug 30, 2010 9:05 am
bridged wireless in station mode is not going to work. If you don't like wds, you can make vpls. here is an example
http://wiki.mikrotik.com/wiki/Transpare ... using_MPLS
Users browsing this forum: andrewe02000, eworm, MSN [Bot], mszru, sindy, slaystin, spr41178 and 87 guests
