areearee
transfer licence form IDE Flash To HDD
Mon Sep 13, 2010 11:52 am
Dear all,
i have three IDE Flash installed Mirotik Router OS form factory but now i have problem with them two of them stop and give this error messege (loading system with initrd) and another give this error messege (Starting services....:I: Can't open/nova/lib/reset/reset).
if some one have way to fix both problem i will try to fix it, if no way to fix them i will reinstall Router OS i need to use same licence key how i do that?
regards,
AREE :(
gmsmstr
Trainer
Trainer
Re: transfer licence form IDE Flash To HDD
Mon Sep 13, 2010 3:38 pm
Do a netinstall or CD based installation, and then you should be good. If the drive is going bad, you can attempt to contact RouterOS, however, it will be quicker to just get another license.
Dennis Burgess, MCTCE, MTCNA, MCTCTE, MTCWE, MTCNIE, A+, N+, MCP, MTCSE Mikrotik Certified Consultant / Trainer
Need Mikrotik Support: http://www.linktechs.net -- Link Technologies, Inc.
-- Author of "Learn RouterOS: Second Edition"
fewi
Mon Sep 13, 2010 4:00 pm
Users browsing this forum: Bing [Bot], Google [Bot] and 50 guests
