FIPTech
5.0 RC1 SSH crash again
Sat Sep 25, 2010 12:03 pm
I got again a SSH crash with 5.0 RC1 on RB750G.
This seems to produce randomly, after a few hours to a few days of uptime.
I'm using dude to probe the SSH service on this router.
I'm not alone to have this problem. From another thread in the forum :
"Confirm STILL bug in Beta 6 on RB-450G
got scared when I couldn't log into remote site... luckily I have a tunnel that accepted a telnet session. <whew>..."
MichelePietravalle
Trainer
Trainer
Re: 5.0 RC1 SSH crash again
Thu Sep 30, 2010 2:08 pm
same problem in rb/600 & RB 411U
janisk
Tue Oct 05, 2010 3:48 pm
so, if you remove probe ssh does not crash?
hobbyist
Tue Oct 05, 2010 5:27 pm
I have seen ssh stop working a few times on a rb450g running 5.0 rc1.
This gets it running again:
/ ip service
disable ssh
enable ssh
The time before it fails, it prompts for passphrase, and even with the correct passphrase cut 'n pasted in, it fails. After that, no response on port 22 until I restart. Then ssh login works fine.
janisk
Fri Oct 08, 2010 4:04 pm
yes, that disable/enable stops (if working) and starts (if not working) ssh server. If after that it starts to work please make supout.rif file and send it to us, so we can fix the problem.
guroth
Tue Oct 19, 2010 8:05 pm
I have recently started having this issue on an x86 machine running 4.7. I upgraded it to 4.11 and ran into the same issue about 4 days later. Rebooting has fixed it, I will try disable/enable the ssh service if it happens again.
janisk
Wed Oct 20, 2010 11:34 am
that is completely different issue as it is completely different peace of software (but it does same thing)
bdr
Trainer
Trainer
Mon Oct 25, 2010 4:19 pm
The same on rb333 with 5.0rc1. After some time the ssh server crashes/it's impossible to connect to it.
Disable then enable helps for some time...
regards,
bdr
Users browsing this forum: cedie, plango, sindy, vasconeyov and 74 guests
