MUM Europe 2020
conchalnet
latency in PPPoE connections
Fri Oct 01, 2010 7:52 pm
Hi all!
I started to use PPPoE last week in my customers that are using 5.8Ghz radios. With fixed IP Address I've the latency between 1ms and 5ms and when I setup PPPoE the latency is between 30ms and 40ms.
The PPPoE server is a RB1000 and the server is running on the ether2. The local IP address is on ether2 interface. I've about 50 PPPoE connections together.
How can I solve this problem?
riaanmaree
Re: latency in PPPoE connections
Mon Oct 04, 2010 11:41 am
We had the same problem when using encryption with PPPoE sessions. When disabling encryption it resolved it for us. We used a RB450G as the PPPoE server and Ubiquity devices as clients.
conchalnet
Tue Oct 05, 2010 12:30 am
Thanks riaanmaree,
But I don't use encryption in my PPPoE sections.
I don't know what is the problem... I'm looking for a solutions.
Fabrício
boardman
Fri Jun 15, 2012 8:05 pm
Hi Fabricio, did you found an answer to this issue? We are experiencing the same here.
Regards
J. Boardman
Users browsing this forum: Google [Bot], llag, MSN [Bot], SiB, ste and 84 guests
