MUM Europe 2020
dormador
problems with RADIUS and pppoe
Fri Oct 15, 2010 3:36 pm
Hi every one
I used radius and all points take authentication of a single box without any problems .
the problem, which happened to me there are as follows, I have a new network I have to merge three Internet lines where after merger i have an imbalance! The imbalance was due to the exit of the request of validated across the Line of Internet is not defined in main radius I mean, if if the request of validated went out of the pppoe1 be acceptance ..the request of the pppoe 2 or pppoe3 shows a letter there was no response from server I hope a solution to this problem.... so that it would be the exit of the request of the authentication from pppoe1 only
How can i do that !!
Ibersystems
Re: ooooops a big problem for me need an immediate solution
Fri Oct 15, 2010 3:41 pm
you can use mangle to mark all packets with destination your radius server IP, and mark all with a routeing mark to use only pppoe1
Martín
martinruiz at ibersystems.es
Experto en redes WiFi y enlaces WiFi.
Facebook: @Ibersystems
Twitter: @Ibersystems
Certified in Traffic Shaping, Wireless, Internetworking, Routing and User Management.
MTCTCE - MTCWE - MTCINE - MTCUME - MTCRE
dormador
Fri Oct 15, 2010 4:29 pm
thanks Ibersystems for rapid assistance
this is a mangle where is the point which will help in solving the problem .
 /ip firewall mangle> p
 0   chain=input action=mark-connection new-connection-mark=wan1 passthrough=yes
     connection-state=new in-interface=pppoe-out1
 1 I chain=input action=mark-connection new-connection-mark=wan2 passthrough=yes
     connection-state=new in-interface=pppoe-out2
 2 X chain=input action=mark-connection new-connection-mark=wan3 passthrough=yes
     connection-state=new in-interface=pppoe-out3
 3   chain=output action=mark-routing new-routing-mark=wan_1 passthrough=no
 4   chain=output action=mark-routing new-routing-mark=wan_2 passthrough=no
 5 X chain=output action=mark-routing new-routing-mark=wan_3 passthrough=no
 6   chain=prerouting action=mark-connection new-connection-mark=wan1
     passthrough=yes dst-address-type=!local in-interface=lan
     per-connection-classifier=both-addresses-and-ports:3/0
 7   chain=prerouting action=mark-connection new-connection-mark=wan2
     per-connection-classifier=both-addresses-and-ports:3/1
 8 X chain=prerouting action=mark-connection new-connection-mark=wan3
     per-connection-classifier=both-addresses-and-ports:3/2
 9   chain=prerouting action=mark-routing new-routing-mark=wan_1 passthrough=yes
     in-interface=lan connection-mark=wan1
10   chain=prerouting action=mark-routing new-routing-mark=wan_2 passthrough=yes
     in-interface=lan connection-mark=wan2
11 X chain=prerouting action=mark-routing new-routing-mark=wan_3 passthrough=yes
     in-interface=lan connection-mark=wan3
I have to disabled pppoe2&pppoe3 until the end of the imbalance
Ibersystems
Fri Oct 15, 2010 4:47 pm
hi,
I think first you have to mark connection, then mark packet and later mark routing of these packets.
Martín
dssmiktik
Forum Veteran
Forum Veteran
Sun Oct 17, 2010 11:39 pm
dormador,
When you choose a topic, please choose something more descriptive. I just don't like clicking into the topics having no idea what they're about, when people say they need immediate solution.
update: topic has been changed
Doug
dormador
Re: problems with RADIUS and pppoe
Sat Oct 30, 2010 6:10 pm
Thanx everybody but until know the problem stell here !!!
Users browsing this forum: MSN [Bot] and 78 guests
