leon84
Double Internet Gateway
Tue Oct 19, 2010 4:51 pm
Hi to all,
I would implement a redundant gateway in my routeros.
In particular consider that I have a RouterBoard with 3 interfaces: eth0, eth1 and eth2
eth0 and eth1 have different internet link, while eth2 is the ethernet interface connected to my lan.
I would to use eth0 as primary link to internet and gateway for my lan, but if link is down I would that router switch automatically on eth1.
In which way Can I implement this one?
mrz
Re: Double Internet Gateway
Tue Oct 19, 2010 5:15 pm
Add two default gateways with check-gateway=ping, and one with greater distance. If primary fails then other one with greater distance will become active.
http://wiki.mikrotik.com/wiki/Two_gateways_failover
There are also other examples that may be useful:
http://wiki.mikrotik.com/wiki/User/Routing
el berto
Thu May 14, 2015 1:02 pm
But "check ping" would only check for gateway interface, not for ISP connection....
So, if my ADSL modem (192.168.1.1/24) is up but without internet connection I would have my default gateway set on 192.168.1.1, but non connection to outside.......
ZeroByte
Thu May 14, 2015 6:35 pm
When given a spoon,
you should not cling to your fork.
The soup will get cold.
Users browsing this forum: No registered users and 102 guests
