MUM Europe 2020
ctech4285
RB433 no disk space can't unistall packages?!
Wed Oct 20, 2010 8:08 pm
is there a way to free up some space on an RB433 (ROS 5beta6) whit 0bytes free without physical access?
i installed dude on an rb433 with 5mb left over space over time the data source filled up all the remaining space....
i tried removing the data sources from the client app but it does not look like it freed up the space on the RB433. i can't uninstall anything or delete anything, there are no files expect a log file with 99 bytes...
the thing is at a remote location and a reinstall would be difficult..
Feklar
Re: RB433 no disk space can't unistall packages?!
Wed Oct 20, 2010 11:30 pm
Try going to system/packages and setting a few of them for uninstall. I've never installed the Dude, but I think it should be listed in there as well.
ctech4285
Thu Oct 21, 2010 1:18 am
yeah i did that, but nothing will uninstall, i think ROS needs disk space to do it..
no error message nothing, after reboot nothing changed
anaktos
Tue Aug 16, 2011 6:27 pm
I have the same problem and I can not uninstall or disable any packet.
Someone could fix this?
______
MTCNA
normis
Wed Aug 17, 2011 8:48 am
Only reinstall can fix it.
anaktos
Wed Aug 17, 2011 3:39 pm
ok, I have to do it then
thanks
______
MTCNA
Users browsing this forum: aboiles, hadib24, slv and 76 guests
