wildbill442
Bandwidth Test Tool and RADIUS
Thu Oct 21, 2010 8:30 pm
FYI
The bandwidth test server only seems to look at the local users file for authentication. Is there a way to allow it to query the RADIUS server for auth ?
William Burnett
Network Engineer
omidkosari
Trainer
Trainer
Re: Bandwidth Test Tool and RADIUS
Fri Oct 22, 2010 11:23 am
+1
interesting feature
janisk
Fri Oct 22, 2010 2:57 pm
no there is no such possibility to hook up bandwidth-test to authorize against RADIUS. That would require complete rework of named service to add such ability.
MichelePietravalle
Trainer
Trainer
Fri Jan 07, 2011 10:10 am
ok but it's a problem; i have setted-up a centralized auth for some tech and local users are disabled! now i have make a workaround with a user only for bandwidth but its a workaround.... :(
Yasir
Wed Oct 23, 2013 11:56 am
Just thought to bring the subject alive again , it's been 2 years , and we can certainly say that we are using more and more of the product all over the world , as main/secondary nodes in the network
Adding this feature " Radius Authentication for Bandwidth Test " is necessary now to avoid problems of having to add a simple user just for Btest
alex1
Fri Jan 12, 2018 4:36 am
Folks,
We hit that issue today and figured out that "Bandwidth Test" tool works ONLY with locally created users which doesn't make any sense!
To those who will be looking for a reason why they're getting the log message like that:
echo: system,error,critical login failure for user XXX via bandwidth-test
Janisk, is it really hard to implement? This thread started back in 2010 and it's still not implemented yet. Could you please confirm that it's not fixed yet in any software release and please add it into the roadmap, if possible.
Is there any workaround like custom tool for Bandwidth Test with preconfigured username/password? For example, we can create RO local username on all the device just for Bandwidth Test, then create another custom tool where we would specify those credentials rather than using login/pass configured in the Dude for a device.
Please advise.
JimmyNyholm
Tue Jan 30, 2018 12:57 am
I Did stumble over this today when I tried to uppgrade my sequrity a couple of notches.
+1000
Please add radius (PAP one time passwords) support to the bandwith testserver as well and only if radius server returns that user has a group that has the access offcourse
Users browsing this forum: JustDobby and 82 guests
