firewallrule
How can Setup a good failover
Thu Oct 21, 2010 11:22 pm
I notice that my fail over only switch when the gateway is off or cable unplug.
I have the 3g Internet to my Mikrotik. I want it to be switch if one of the remote internet is down vis versa.
I moderm could be on or gateway reply but not accessing internet.
I urgently need help please.
fewi
Re: How can Setup a good failover
Thu Oct 21, 2010 11:29 pm
The fastest way to solve that is to search the forum for 'failover'. That question gets asked sometimes more than once a day.
firewallrule
Mon Oct 25, 2010 10:27 pm
i have search the forum but could get similar issue treated.
What i want instead of pinging gateway to check availability, i want it replaced with a remote host ip address or the isp DNS server IP.
Thanks 4 upcoming response
Feklar
Mon Oct 25, 2010 10:34 pm
There are 3 ways.
1.) Use the built in Netwatch functionality of the MikroTik to handle a basic script for enabling/disabling routes.
2.) Make your own more complicated script to do the same thing, gives you more control of the functionality itself.
3.) Use the script-less method, this has been posted on multiple times.
All of these things are here in the forum, and there are also examples in the wiki that will get you pointed in the right direction.
firewallrule
Tue Oct 26, 2010 11:14 pm
I know nothing about scripting.
Can someone carry me along?
Chupaka
Thu Nov 04, 2010 9:28 pm
Users browsing this forum: No registered users and 69 guests
