TKITFrank
RouterOS v5 RC2
Wed Oct 27, 2010 5:58 pm
What's new in 5.0rc2 (2010-Oct-27 16:20):
*) wireless nv2 - encryption support;
*) tool fetch - support ftp STOR;
*) ospf - fixed crash when working with external LSA that contain
forwarding addess;
*) ipsec - supports NAT-T drafts;
*) ipsec - added debug logging, to maintain same log verbosity as before with
'ipsec' topic now use topics 'ipsec,debug,!packet';
*) ipsec - make it work with EoIP, GRE, PPTP and L2TP;
*) support for Atheros AR9271 wireless chip;
*) added support for more Intel 82575/82576 PCI-Express Gigabit Ethernet cards;
*) added support for idle detection on RB1xx/RB5xx in /tool profile;
*) fixed Wireless manual tx power configuration for 11n rates in WinBox;
*) fixed torch;
alexspils
Re: RouterOS v5 RC2
Wed Oct 27, 2010 7:51 pm
installed it on my home 411ah based ap.dynamic Dhcp+simple nat setup forking fine.Noticed Distance value in wireless status, cool :)
jcem
Re: RouterOS v5 RC2
Wed Oct 27, 2010 7:59 pm
- Showing 28V constantly on RB433AH - showed correct 13V in rc1
- Somehow draws a lot more power. The RB433AH reboots with "power outage" even if I disable two radio cards
I know that I'm short on amperage to this site due to over 500m power-cord, but has never
been un issue before...
Had to rapidly downgrade to rc1 again
- CPU goes 100% randomly and reboots - this happens on all of my RB's
RGDS
Copper
Re: RouterOS v5 RC2
Wed Oct 27, 2010 8:12 pm
SNMP bug still present.
PCQ not work properly.
rpress
Re: RouterOS v5 RC2
Wed Oct 27, 2010 8:15 pm
Wow, support for ipsec NAT-T!
Still crashes WinBox when opening up an IPv6 route on my RB750. It has done this ever since the new WinBox GUI look. It did this even with a clean install.
gustkiller
Re: RouterOS v5 RC2
Wed Oct 27, 2010 8:17 pm
finally,
going to test it tonight!
Mikrotik Certified Consultant
TKITFrank
Re: RouterOS v5 RC2
Wed Oct 27, 2010 8:58 pm
The connection-mark / Mangle passthrough bug is gone as well.
Looks like the cpu on my RB800 can now be set to 1200MHz it was 1000Mhz as max before. 8)
MTCNA
"I don't believe UNIX is Utopia. It's just the best set of tools around."
colebert
Re: RouterOS v5 RC2
Wed Oct 27, 2010 9:05 pm
Missing dBs between v4.11 and 5.0rc2
http://forum.mikrotik.com/viewtopic.php ... 1&p=233528
Amateurs built the Ark.
Professionals built the Titanic.
ayufan
Re: RouterOS v5 RC2
Wed Oct 27, 2010 9:20 pm
- bug in torch still present
- nat-t not working with windows xp
hAP AC, TP-Link Archer C7 v2, RB951G, RB450G, RPI2, RPI zero
roadracer96
Forum Veteran
Forum Veteran
Re: RouterOS v5 RC2
Wed Oct 27, 2010 10:43 pm
I just tried it with a PSK and it worked on my Win7 laptop., Dunno about WinXP. But that is a step in the right direction. Gotta try it with multiple clients/certificates next.
ayufan
Re: RouterOS v5 RC2
Wed Oct 27, 2010 11:02 pm
Did you try behind NAT?
colebert
Re: RouterOS v5 RC2
Wed Oct 27, 2010 11:06 pm
When switching between v4.11 and rc2 the MCS rates increase one level.
For example, when I upgraded a link that was set for MCS5 the link came back up set for MCS6. I was able to reproduce this problem.
gustkiller
Re: RouterOS v5 RC2
Wed Oct 27, 2010 11:11 pm
torch working here (x86)
w0lt
Long time Member
Long time Member
Re: RouterOS v5 RC2
Thu Oct 28, 2010 2:00 am
The firewall is still acting goofy on the drop chain. This was preset on RC1 as well....
-tp
MTCNA - 2011
" The Bitterness of Poor Quality Remains Long After the Sweetness of Low Price is Forgotten "
roadracer96
Forum Veteran
Forum Veteran
Re: RouterOS v5 RC2
Thu Oct 28, 2010 2:56 am
Yep. From my laptop behind NAT.
Chupaka
Re: RouterOS v5 RC2
Thu Oct 28, 2010 3:27 am
'properly'?..
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
ayufan
Re: RouterOS v5 RC2
Thu Oct 28, 2010 3:29 am
I did test it a minute ago and it doesn't work. Neither with nat-t enabled nor disabled ;)
wispwest
Re: RouterOS v5 RC2
Thu Oct 28, 2010 5:02 am
I wish we could really see the real rated TX power for the SR71-15. Looks like its only getting worse...as shown from Colberts screen shots.
mattx86
Re: RouterOS v5 RC2
Thu Oct 28, 2010 6:50 am
From the bugs I've reported in 5.0rc1 and from what I've re-tested and observed in 5.0rc2, it seems that the following changes are missing from the 5.0rc2 change log (correct me if I'm wrong):
*) ip packing - no longer locks up system;
*) log - now shows source IP address for SSH connections, like it used to;
*) log - now shows ethernet link status in the log (simple up/down status);
Regarding torch (on my RB532/mipsle system):
While running a web-based speed test with torch running and the LAN interface's traffic graph visible, I can see that the download portion of the speed test continues to be graphed, while the connection listing for it in torch will randomly disappear and reappear. I assume this occurs on the upload portion of the test as well.
Regarding NAT-T:
The changelog only seems to indicate support for NAT-T under IPSec, and not NAT-T for general use.
To be sure, I...
- setup a simple web server on my computer
- enabled a NAT rule for it
- disabled my Firewall drop rules on the input and forward chains
- made sure I could access it from my computer
- made sure that Google Translate could access it and translate it (I've even got the IP address where Google Translate connected - 74.125.75.17)
- attempted to access it using the same URL that I gave Google translate, and it did not work.
roadracer96
Forum Veteran
Forum Veteran
Re: RouterOS v5 RC2
Thu Oct 28, 2010 7:54 am
You are thinking about the wrong thing. Nat-T for ipsec has nothing to do with the firewall rules. It has to do with the client behind the firewall connecting to a IPSEC server out in the wild reporting a private IP but originating from a public IP.
macgaiver
Re: RouterOS v5 RC2
Thu Oct 28, 2010 8:12 am
Probably there is some issue with some specific option/value combination, you should go through your firewall - with disable/enable portions of rules (be carefull do not lock yourself out the router) and this way you should be able to find exact rule/option in the rule, that don't let your firewall start properly (that is the reason for these interesting numbers)
Please, keep us posted what option and what values were problematic.
With great knowledge comes great responsibility, because of ability to recognize id... incompetent people much faster.
macgaiver
Re: RouterOS v5 RC2
Thu Oct 28, 2010 8:38 am
Regarding NAT-T:
The changelog only seems to indicate support for NAT-T under IPSec, and not NAT-T for general use..
Yep, you are right only IPSec:
Lets log winbox ---> IPsec ---> Peer tab ---> press "+" ----> and here it is " NAT Traversal" checkbox - enjoy
uldis
Re: RouterOS v5 RC2
Thu Oct 28, 2010 9:32 am
please provide us more info with the screenshots and description how did you test it. Send that info to support@mikrotik.com. Also include the support output files from both versions.
uldis
Re: RouterOS v5 RC2
Thu Oct 28, 2010 10:30 am
-tp
problem is with the 'content' matcher. Avoid using it and rest of the firewall will work fine. We will fix it in the next version.
hurley12345
Re: RouterOS v5 RC2
Thu Oct 28, 2010 11:12 am
I have numerous SR-71's in Place. and would like to get the right TX power for these Wireless cards.
brianchrist
Re: RouterOS v5 RC2
Thu Oct 28, 2010 12:39 pm
where i can download it?
the download link at http://www.mikrotik.com/download.html is broken
normis
Re: RouterOS v5 RC2
Thu Oct 28, 2010 12:41 pm
which link is broken? works for everyone else
ste
Re: RouterOS v5 RC2
Thu Oct 28, 2010 1:20 pm
This is completely independent to security profile set in Interface->Wireless?
So when connecting with 802.11 or nstreme security profile is taken?
When connecting with nv2 the PSK set in NV2 is taken?
normis
Re: RouterOS v5 RC2
Thu Oct 28, 2010 1:21 pm
when you use Nv2 on the AP, then only Nv2 clients can connect anyway. No other settings matter. Yes, Nv2 security is configured separately in the Nv2 menu.
brianchrist
Re: RouterOS v5 RC2
Thu Oct 28, 2010 1:55 pm
got it. it's only available on czech and germany site
normis
Re: RouterOS v5 RC2
Thu Oct 28, 2010 2:02 pm
if you find mirror links that don't work, let us know please
Stanislav Hrncir
Re: RouterOS v5 RC2
Thu Oct 28, 2010 6:05 pm
Poor stability than prerelase of rc2 - all things was ok on prerelase.. now its broken
1. Bios upgrade shows old bios "" upgrade bios "2.27" after upgrade all bios settings go to default and any change / console or manually in bios / doesnt have any change" only option is take "good" 2.27 bios and flash it
2. Unstable with full throughtput or btest - goes to reboot with kernel panic
3./system backup load file= ..... hangs rb
4. /system check-installation shows bad crc for kernel
All this bugs are on RB800 and x86
Chupaka
Re: RouterOS v5 RC2
Thu Oct 28, 2010 6:26 pm
maybe that's the reason? it's okay for me on x86
wildbill442
RB1100
Thu Oct 28, 2010 8:13 pm
My switch group 1 on my RB1100 seems to have stopped working after the upgrade... Had to move hosts to the other switch group in order to restore connectivity...
I haven't done much troubleshooting yet, I'll try resetting the configs and reconfiguring and report back.. Just wondering if anyone else had similar problems?
William Burnett
Network Engineer
Stanislav Hrncir
Re: RouterOS v5 RC2
Thu Oct 28, 2010 8:51 pm
but this is same problem for all rb800 that i have... and some x86
wildbill442
Re: RB1100
Thu Oct 28, 2010 9:00 pm
Downgrading to 5.0rc1 and then removing the switch configuration and re-adding it seemed to fix the problem.
After upgrading back to 5.0rc2 removing the switch configuration seemed to make my host lose connection even though I was connected through the second switch group. Trying to readd the ports to the switch again caused me to lose connection.
Under RC2 switch group 1 (ether1 - 5) will show physical links (based on router and host LAN LEDs) but when actual connectivity is tested it shows net unreachable as if there were no physical connection.
Downgrading to RC1 fixes the problem... I'll forward a supout.rif to support.
William Burnett
Network Engineer
gustkiller
Re: RouterOS v5 RC2
Fri Oct 29, 2010 1:42 am
here so far so good, dispite the rx drops about 3k a day..
normis
Re: RouterOS v5 RC2
Fri Oct 29, 2010 7:42 am
This is fixed in RC3, sorry about that. Wireless crashes on big throughput. I think all of your problems are actually one problem, but will check.
roddie
Re: RB1100
Fri Oct 29, 2010 8:21 am
Same problem here -- My interfaces were a big mess after going from RC1 to RC2. Most of them didn't come up properly; perhaps a negotiation issue. Downgrading to RC1 (and to 4.x) fixed it.
normis
Re: RouterOS v5 RC2
Fri Oct 29, 2010 9:00 am
clarify both please
normis
Re: RouterOS v5 RC2
Fri Oct 29, 2010 9:45 am
MCS settings were messed up in Winbox in previous versions.
Winbox had mcs-1, mcs-2, etc
while console had mcs-0, mcs-1.
Fixed it in v5.0rc2. Winbox now has mcs-0, mcs-1, etc.
EMOziko
Re: RouterOS v5 RC2
Fri Oct 29, 2010 11:53 am
Hello, I cant download rc2.
it said 404 - Not Found :shock: :? :(
We want new versions of The Dude!!!!!!!
normis
Re: RouterOS v5 RC2
post link which didn't work! try other links (other mirror, or torrent)
EMOziko
Re: RouterOS v5 RC2
Fri Oct 29, 2010 12:01 pm
http://download.mikrotik.com/routeros-mipsbe-5.0rc2.npk
:( i ll try torrent now.
EMOziko
Re: RouterOS v5 RC2
Fri Oct 29, 2010 12:04 pm
yeah thank you serbia, finnaly i downloaded from serbian mirror :)
martini
Re: RouterOS v5 RC2
Fri Oct 29, 2010 12:20 pm
fixed issue with torch and intel ethernet, but now if i enable QUEUE i cant see TX traffic on interface )) because queue catch traffic before torch )) and if i disable queue i can see all traffic )
normis
Re: RouterOS v5 RC2
Fri Oct 29, 2010 12:26 pm
works for me
martini
Re: RouterOS v5 RC2
Fri Oct 29, 2010 3:14 pm
Chupaka
Re: RouterOS v5 RC2
Fri Oct 29, 2010 3:16 pm
works for me =)
npyoung
Re: RouterOS v5 RC2
Fri Oct 29, 2010 5:04 pm
Tried it on several of our RB433AH...serial kernel failures and reboots. Had to roll back to rc1.
npyoung
Re: RouterOS v5 RC2
Fri Oct 29, 2010 5:15 pm
BTW, noticed that as long as there wasn't much traffic going through the RB433AH's that were undergoing serial kernel failures with rc2 they would stay up long enough for me to upload rc1 and downgrade. So...if you are testing on a board that isn't in production (of course you are), you may not see this problem. Systems under load wouldn't stay up for more than a few minutes at a time before crashing.
wildbill442
Re: RouterOS v5 RC2
Fri Oct 29, 2010 6:37 pm
*) fixed problem - bad boot/kernel crc was reported on powerpc boards
when in fact it was good;
Normis,
Does RC3 fix the problem with the switch chip / interfaces I described above?
William Burnett
Network Engineer
w0lt
Long time Member
Long time Member
Re: RouterOS v5 RC2
Fri Oct 29, 2010 7:46 pm
-tp
The problem still exists with RC3.
-tp
MTCNA - 2011
uldis
Re: RouterOS v5 RC2
Fri Oct 29, 2010 8:33 pm
Normis,
No,the fix for the switch chips will be only in the RouterOS v5.0rc4 which will me next week. Sorry :(
uldis
Re: RouterOS v5 RC2
-tp
-tp
The fix will be only in RC4, sorry :(
uldis
Re: RouterOS v5 RC2
Fri Oct 29, 2010 8:34 pm
Please upgrade to RouterOS v5.0rc3 - it will fix the crashing.
jcem
Re: RouterOS v5 RC2
Fri Oct 29, 2010 9:02 pm
I can confirm it works fine and doesn't crash on the links 3 links I've tested so far
8)
RGDS
Copper
Re: RouterOS v5 RC2
Sat Oct 30, 2010 2:33 pm
clarify both please
I test x86 -
Seems like PCQ is OK.
It was my mistake in queue tree config.
SNMP OIDs of "CPU load" return null or not correct values.
SNMP OIDs RFC1213-MIB::ipRouteDest not present at all (in v4 works fine).
SNMP OIDs of Queue Tree counters works only when i connect to router with Winbox and open window Queue Tree. As soon as I disconnect Winbox all OIDs of Queue Tree return null.
RC3 not tested yet.
Chupaka
Re: RouterOS v5 RC2
Sat Oct 30, 2010 3:57 pm
I can't see such behaviour neither on rc2, nor rc3 (x86)
Copper
Re: RouterOS v5 RC2
Sat Oct 30, 2010 4:44 pm
But i see. On pre1-RC2, pre2-RC2, RC2.
And we really need an RFC1213-MIB::ipRouteDest.
When will it be available in v5 ?
When i downgrade to v4 SNMP is work fine.
What additional information is needed from me to discover this problems?
Chupaka
Re: RouterOS v5 RC2
Sat Oct 30, 2010 6:21 pm
with no Active Users I do
snmpwalk -v2c -c public ROUTER 1.3.6.1.4.1.14988.1.1.2.2.1.7
- it shows correct results:
SNMPv2-SMI::enterprises.14988.1.1.2.2.1.7.16777216 = Counter64: 0
SNMPv2-SMI::enterprises.14988.1.1.2.2.1.7.16777217 = Counter64: 0
SNMPv2-SMI::enterprises.14988.1.1.2.2.1.7.16777218 = Counter64: 259317068
Copper
Re: RouterOS v5 RC2
Sat Oct 30, 2010 7:04 pm
Just tested.
Strange.
For monitoring i use ZABBIX and with v4 ROS all fine.
On v5 - was as I explained earlier (WinBox trick).
Indeed, snmpwalk in command line works, but ZABBIX did`t receive any data of Queue Tree OIDs without WinBox.
Miracles.
Where to find the cause?
Chupaka
Re: RouterOS v5 RC2
Sat Oct 30, 2010 7:09 pm
run Wireshark, check for exact SNMP queries...
Copper
Re: RouterOS v5 RC2
Sat Oct 30, 2010 8:01 pm
I found the error !
Chupaka, try
tshark -V -Ttext ip host ROUTER and port 161 | grep Counter64
Return values are always the same, they do not change!
They begin to change only when you run WinBox and open Queue Tree window.
That is why I've seen zero flow rate in ZABBIX.
Mikrotik, I'm doing for you your job :)
When you fix this error
and CPU OIDs
and RFC1213-MIB::ipRouteDest OID
Chupaka
Re: RouterOS v5 RC2
Sat Oct 30, 2010 8:30 pm
actually, that was the second thing I checked... values were changing =)
Copper
Re: RouterOS v5 RC2
Sat Oct 30, 2010 8:32 pm
No.
For PCQ queues they do not change.
Copper
Re: RouterOS v5 RC2
Sat Oct 30, 2010 8:52 pm
Chupaka, when
values changing.
but if request for one queue counter
snmpwalk -v2c -c public ROUTER 1.3.6.1.4.1.14988.1.1.2.2.1.7.16777218
values always the same.
Try.
Chupaka
Re: RouterOS v5 RC2
Sat Oct 30, 2010 9:46 pm
now I can confirm that on rc3 =)
data refreshes only when Queues window is opened in WinBox or when you do snmpwalk over the whole tree... have you opened a support ticket?
p.s. I must use rc3 in production - previous versions do not see most of the hardware of that server... how many 'features' will I face on that way?..
p.p.s. as a workaround, I will use that:
/system scheduler
add disabled=no interval=4s name=schedule1 on-event="/queue tree print stats" \
    policy=read start-date=jan/01/1970 start-time=00:00:00
Copper
Re: RouterOS v5 RC2
Sun Oct 31, 2010 12:21 am
No, i did`t open a support ticket.
Thanks for the workaround solution.
Copper
Re: RouterOS v5 RC2
Sun Oct 31, 2010 11:34 am
No, the PCQ error is present - http://forum.mikrotik.com/viewtopic.php?f=2&t=46206
I thought that the case is not the optimal settings, but no.
PCQ still does not work as expected.
And I noticed that immediately after reboot PCQ works about well, but over time begins to run from bad to worse.
Previously, I used v3.30 RB1000 as PCQ-shaper. All works fine.
Then I had to use the x86, because high CPU load on RB1000.
And the problems with shaper started.
I test 4.11, 4.12, 5.pre1-RC2, 5.pre2-RC2, 5.RC2 - PCQ not work as in 3.30.
Chupaka
Re: RouterOS v5 RC2
Sun Oct 31, 2010 2:03 pm
how can one repeat that behaviour?
Copper
Re: RouterOS v5 RC2
Sun Oct 31, 2010 2:58 pm
Create 2-4 PCQ queues in Queue Tree and test rate on sub-streams and look at drops.
One queue works OK, but if they are several, and the traffic goes through them at the same time, the problems begin.
Even though the packet rate is small, below the limit-at, multiple drops occur and rate of sub-streams like a sawtooth form and is not approaching its pcq-rate.
English is not my native language, so I sometimes difficult to clearly explained to.
Copper
Re: RouterOS v5 RC2
Sun Oct 31, 2010 4:12 pm
27k packet drops within 5 minutes, although none of the limits are not exceeded and sub-streams is not approaching its pcq-rate!
On RB1000 v3.30 nothing like this was not observed.
Chupaka
Re: RouterOS v5 RC2
Sun Oct 31, 2010 11:06 pm
what type does that rule have?
Copper
Re: RouterOS v5 RC2
Mon Nov 01, 2010 12:32 am
kind=pcq pcq-rate=500k pcq-limit=75 pcq-classifier=dst-address pcq-total-limit=20000
kind=pcq pcq-rate=1M pcq-limit=75 pcq-classifier=dst-address pcq-total-limit=20000
kind=pcq pcq-rate=2M pcq-limit=75 pcq-classifier=dst-address pcq-total-limit=5000
Chupaka
Re: RouterOS v5 RC2
Mon Nov 01, 2010 1:22 am
so, if one user greatly exceeds it's limit (1 or 2 megs) and has over 75 packets in queue, it can lead to drops - nothing unusual for now... I see it in my v3.28 =)
Copper
Re: RouterOS v5 RC2
Mon Nov 01, 2010 11:50 am
Chupaka, I have works fine on v3.30 too. Just test v5.
... Even though the packet rate is small, below the limit-at, multiple drops occur and rate of sub-streams like a sawtooth form and is not approaching its pcq-rate.
In v5 i`ve never seen that bandwidth of PCQ-queue once approached to its max-limit.
I can set 100M limit-at or max-limit, can set 250M - queue rate does not change and rate of drops remain the same.
All I am saying applies to the situation when running a lot of subscribers, more than 50-100 per PCQ-queue.
The impression is that the shaper runs into some inner-limiting and begins to drop packets even in streams that have not reached their pcq-rate.
Copper
Re: RouterOS v5 RC2
Mon Nov 01, 2010 1:31 pm
I test RC3 - seems PCQ works even worse then in RC2.
Chupaka
Re: RouterOS v5 RC2
Mon Nov 01, 2010 1:55 pm
I mean, I have drops on v3.28 too. the reason is not max-limit, but pcq-limit - if user's subqueue is too short to shape peak traffic, the rest packets will be dropped
Copper
Re: RouterOS v5 RC2
Mon Nov 01, 2010 2:13 pm
Look at one stream with
kind=pcq pcq-rate=1000000 pcq-limit=100 pcq-classifier=dst-address pcq-total-limit=15000
Its one file downloading via http from server near the router (not from Internet).
Chupaka
Re: RouterOS v5 RC2
Mon Nov 01, 2010 4:36 pm
and what if you change pcq-limit to, for example, 1000?
Copper
Re: RouterOS v5 RC2
Mon Nov 01, 2010 6:58 pm
Я устал издеваться над своими абонентами и проводить на них тесты.
Совесть уже заела.
Тестируйте сами, если интересно.
Но вообще-то это работа Mikrotik.
Жаль что никто из компании даже не удосужился хоть что-то сказать и дать совет по поводу проблем о которых я тут уже неделю пишу.
Видимо придётся другие решения искать и отказываться от ROS.
Chupaka
Re: RouterOS v5 RC2
Mon Nov 01, 2010 7:10 pm
if you have found a bug - write to support@
this is Community Forum
Copper
Re: RouterOS v5 RC2
Mon Nov 01, 2010 7:27 pm
If you still want to test, create two PCQ-queue and make sure that limit-at in Queue Tree does not work.
Enough to make the same priority and let the traffic through both the queues.
After that, try changing priorities, you ensure that the limit-at not working.
The second thing - the calculation of the free bandwidth and value pcq-rate.
Looks like max-limit simply divides by the current value pcq-sub-stream-count and the pcq-rate decreases to this result. And no matter what there is a lot of free bandwidth, and even limit-at value is not reached.
Or vice versa - pcq-rate multiplied by the pcq-sub-stream-count and the value is said to be occupied bandwidth.
Frankly, I'm tired to try to understand what is happening with PCQ.
I'd love to hear words from Mikrotik.
Chupaka
Re: RouterOS v5 RC2
Mon Nov 01, 2010 7:38 pm
if you have limit-at=10M, pcq-rate=1M and huge traffic in that queue for particular user, packets will be dropped - PCQ will shape/drop it by pcq-rate, HTB's limit-at value will not affect the situation
Looks like max-limit simply divides by the current value pcq-sub-stream and the pcq-rate decreases to this result
I already posted - I cannot repeat this behaviour...
Copper
Re: RouterOS v5 RC2
Mon Nov 01, 2010 7:48 pm
I've said a hundred times - subscribers do not approaching its pcq-rate!
I even brought a picture of rate the one pcq-substream.
So what?
You are tested on hundreds of threads with a version v5?
rmichael
Forum Veteran
Forum Veteran
Re: RouterOS v5 RC2
Mon Nov 01, 2010 7:53 pm
Copper's experience seems to mirror mine. I did notice a change in PCQ behavior between v4.5 to v4.10. Not to repeat myself here's what I wrote in another thread:
Have anyone noticed PCQ dropping packets or unnecessary queuing even though the packet rate is small, way below any of the limits (even limit-at)? Cpu is below 20%, queue size is 50/300, 1-3 PCQ streams.
I see it on RB750 with ROS4.11 and ROS4.10 (150 HTB queues) but I don't see it on RB493AH ROS4.5-same traffic, same rules, queue sizes etc.
Btw, PCQ , per MT, is designed to reach about 80% of bandwidth of max-limit with single stream. This is so new TCP sessions have a room to increase their TCP window sizes and grab more bandwidth and compete with already established streams. In my tests PCQ could never reach max-limit with only one stream. On larger scale, perhaps PCQ reserves a percentage of bandwidth for each stream outright - even if stream does not need as much.
Copper
Re: RouterOS v5 RC2
Mon Nov 01, 2010 8:03 pm
What channels do you work?
You tried to pass through ROS pcq-shaper the flow of more than 100 megabits?
gustkiller
Re: RouterOS v5 RC2
Mon Nov 01, 2010 9:43 pm
Is snmp working when running full bgp table, and just for monitor interface traffic?
Copper
Re: RouterOS v5 RC2
Mon Nov 01, 2010 9:57 pm
I do not use full bgp, just 2 peer and default route, with that, SNMP interface counters works fine.
Copper
Re: RouterOS v5 RC2
Thu Nov 04, 2010 11:25 am
My problem with the shaper resolved by replacing the network card.
Losses at the interface was not, CPU load was low, but the network card was faulty.
x86-based selection and testing equipment for the ROS is an important matter.
Shaper was not guilty.
Chupaka
Re: RouterOS v5 RC2
Thu Nov 04, 2010 2:47 pm
wow, thanks. nice to hear that =)
Users browsing this forum: Google [Bot], pe1chl, ThrowAway and 103 guests
