tarcisionmjr
MK v5 rc3 x86 - bug torch
Mon Nov 01, 2010 10:44 pm
Hello friends, the problem of the torch continues on v5 rc3 x86 ... only see the image ...
Chupaka
Re: MK v5 rc3 x86 - bug torch
Tue Nov 02, 2010 3:43 am
is it only with PPP interfaces?..
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
fxwireless
Tue Nov 02, 2010 6:04 am
I too am having the same problem, first I get a error "could't start - interface not up (6)" then when I press start again it shows me a little traffic on rx only just as the image above.
Edit: it only happens on queue's but when I torch the interface it works fine.
stanioomega
Tue Nov 02, 2010 9:51 am
same here ...
janisk
Tue Nov 02, 2010 10:21 am
we are working to resolve problem that if you have queues enabled you do not see tx data in torch. Disabling queues helps, but that is not much of a workaround. So just hang on for the fix.
martini
Tue Nov 02, 2010 5:19 pm
its bug from RC2, torch get data after queue and dont show traffic.
janisk
Wed Nov 03, 2010 11:21 am
it will be fixed in rc4 as patch is already done
mangust
Fri Nov 12, 2010 1:39 pm
Is there any date for RC4?
Will it be accessible till holidays :wink: ?
What do you think about final release? Does v5 looks pretty stable now ?
tarcisionmjr
Tue Nov 23, 2010 3:22 am
mk v5 rc4 torch work ok...
thank....
Users browsing this forum: Baidu [Spider] and 75 guests
