I would like to set DHCP-client option 60 (Vendor class identifier) in Router OS.
Is there a way that im missing?
Thanks!
I know it is not related but when this feature will be available for PPPoE server ?That manual applies to any custom DHCP option. Add an option, specify option number and value to be sent just like in example.
Really? This is a showstopper for me thenIf you mean to set option 60 for RouterOS DHCP client then unfortunately it is not possible.
Very interesting . what about my old http://forum.mikrotik.com/viewtopic.php?f=2&t=42698In v6 it is possible to add custom options to DHCP client.
Thank you!In v6 it is possible to add custom options to DHCP client.
Hi,Thank you!In v6 it is possible to add custom options to DHCP client.
I confirm that configuration for option 60 is now possible and is working fine (tested on 6.0rc7)![]()
