gustkiller
Feature Request: MPLS RSVP-TE AUTOTUNNEL, MPLS LABEL ECMP
Tue Nov 23, 2010 4:05 pm
As you know , mikrotik mpls implementation only binds one label for ECMP routes, with that, mpls forward using multiple path is broken as only one path is used to forward traffic. As our network have a lot of ECMP paths , we had to disable LDP.
The workaroud to use VPLS tunnels is without ldp is using bgp based VPLS and TE tunnels to generate the MPLS labels.
The problem is that its a pain to configure a lot of TE tunnels like a mesh , as that is the only way , all routers have mpls labels to its loopback addres, and vpls tunnels get running.
imagine having to configure 30 routers with 30 mpls te tunnels to another 29 routers?
an easy ways is to fix mpls to bind labels for all ecmp routes, and enable BGP to work with LDP.
Cisco routers have a feature called AUTOTUNNEL, that automaticaly create TE tunnels between all routers that participate in the ospf-te opaque area.
references.
autotunnel
http://www.cisco.com/en/US/docs/ios/mpl ... unnel.html
http://www.cisco.com/en/US/docs/ios/mpl ... _mesh.html
mpls ECMP
ECMP
http://www.juniper.net/techpubs/softwar ... nfig5.html
MPLS supports equal-cost multipath (ECMP) labels. A nonconfigurable maximum of 16 MPLS paths is supported. On LERs, MPLS ECMP next hops can be used in the IP routing table for non-VPN and VPN routes. On LSRs, an incoming label can point to either an MPLS ECMP next hop or an IP ECMP.
The signaling protocol determines whether ECMP next hops are used. For example, LDP can learn multiple labels for a route from different downstream peers (or one label from a downstream peer that has parallel connections to the router). LDP then creates an MPLS ECMP next hop that can be used in the IP routing table. If LDP also advertises a label, then a forwarding entry is added to the MPLS forwarding table with the ECMP next hop.
Mikrotik Certified Consultant
Eising
Re: Feature Request: MPLS RSVP-TE AUTOTUNNEL, MPLS LABEL ECM
Tue Nov 23, 2010 4:19 pm
I support this feature request.
The road to hell is paved with good intentions.
gustkiller
Tue Nov 23, 2010 5:04 pm
Thanks!!
references.
autotunnel
mpls ECMP
ECMP
eflanery
Wed Nov 24, 2010 9:17 pm
Agreed, those would be great features.
--Eric
lyma
Wed Nov 24, 2010 9:27 pm
I support this feature request too!
Congrats Gustkiller!
MichelePietravalle
Trainer
Trainer
Tue Nov 30, 2010 7:04 pm
i also support ecmp features!!
JorgeAmaral
Trainer
Trainer
Wed May 18, 2011 9:00 pm
I support this feature request too.
gustkiller
Wed May 18, 2011 9:02 pm
thanks!
gustkiller
Sun Sep 25, 2011 12:48 am
any news?
saaremaa
Sat Sep 29, 2012 2:06 pm
any news?
CMDR Saaremaa (Gutamaya Sierra Alpha Alpha)
nz_monkey
Sat Sep 29, 2012 11:51 pm
Auto tunnel would be great. I support this request.
http://thebrotherswisp.com/ | Mikrotik MTCNA, MTCRE, MTCINE | Fortinet FTCNA, FCNSP, FCT | Extreme Networks ENA
gustkiller
Thu Feb 21, 2013 9:24 pm
any news on MPLS ECMP?
lyma
Thu Feb 21, 2013 9:33 pm
Still alive?
japaeye4u
Mon Dec 08, 2014 9:09 pm
I also want
lyma
Wed Dec 24, 2014 12:07 am
Nothing!
I expected there to be more respect for customers by the Mikrotik... maybe one day...
wildbill442
Wed Nov 18, 2015 9:35 pm
Nothing!
I too need support for MPLS over ECMP connections. When will this be implemented?
William Burnett
Network Engineer
rememberme
Re: Feature Request: MPLS RSVP-TE AUTOTUNNEL, MPLS LABEL ECMP
Mon Jun 19, 2017 8:48 pm
Very needed.
+1
magnavox
Wed Dec 27, 2017 10:31 pm
Any news for MPLS and ECMP?
Best Regards...
JimmyNyholm
Tue Jan 02, 2018 8:10 pm
2018 Now any news here +1
Users browsing this forum: Google [Bot], heidarren and 54 guests
