I have noticed a lot of p2p slipping through lately. Has Kazaa protocol been updated and Mikrotik not support it yet? Does Mikrotik support Ares?
Matt
thanks for you input. Which version of MT are you running?Just installed the Kazaa and added a mangle rule to mark the kazaa p2p and it started to count the traffic when I strarted to use it. and it counted all the downloaded files traffic.
About Ares - you can only drop it, it isn't possible to mark - I should be written also in the manual.
Yes, I downloaded Kazaa v3 from the download their download site, installed (they have lot of adwares). Added mangle rules in the forward chain to mark p2p traffic and added queue rules with that flowmark. Searched some mp3 files and started to download - all is marking....thanks for you input. Which version of MT are you running?
Which version of KaZaA did you try?? V 3??
Ares - drop only, yep I know several other post point this out but thanks for mentioning it. Have you tried Ares 1.8.1 client - it go's straight through MT even when rule uses "DROP"
I am opnly interestd in DROP function as intended use is on school LAN.
