mkeding
Usermanager CoA not disconnecting users
Fri Dec 10, 2010 2:03 am
I have 5rc5 installed using a fairly simple PPPoE setup using UserManager. Everything works ok except for CoA. When I disable a user in user manager, I see the request in the logs on the router board. However, I get the following error
"Hotspot error info debug: Radius Disconnect Request for unknown ip 192.168.101.105"
This is the address assigned by PPoE and I can see it under Active connections in PPP. I don't have a Hotspot set up.
The user is not disconnected. If I disconnect and try to reconnect, the user is disabled so I know that part works. In the Radius Incoming screen, I see 1 request and 1 Naks. Port is set for 1700.
Any ideas?
Jrslick22
Re: Usermanager CoA not disconnecting users
Wed May 11, 2011 3:51 pm
CoA is not currently supported
Alfabi
Fri May 13, 2011 11:03 am
use Radius manager v 3.9 it is support CoA
http://www.bios-computer.com - Fastest WISP in UA
Users browsing this forum: boyko, knowledgemonster, Shadowtm and 119 guests
