Hi
Ive been using Robin Mesh, and really like the fact that I can get the routers to check in via HTTP so you can check they are running etc vi a status page. Ive had a quick google on the site, but cannot find out if its possible to implement something similar via the schedule/crontab.
Im thinking that i could just do a wget http://checkin.server.com/checkin.php?r ... uptime=id2 etc, replacing ids with the results from variables using script.
Is this possible on the routerOS?
regards
