MUM Europe 2020
normis
IPv6 TODO
Thu Dec 30, 2010 9:01 am
New years gift to our loyal forum users. This is the list of features we have planned to complete within the next 6 months, for v5:
- IPsec IPv6 support with IKE v2 IKE v3 (probably in v6 beta)
- IP Pool support; for PPP and DHCP (to manage networks instead of addresses)
- IPv6 Address auto-configuration from other routers
- IPv6 DHCP stateless configuration & prefix assignment
- Hotspot
- Webproxy
- DNS64
- NAT64
- SSTP IPv6
- L2TP IPv6 (also probably only for v6 beta)
blake
Re: IPv6 TODO
Thu Dec 30, 2010 10:33 am
You probably mean stateful address allocation.
Any plans to support MPLS 6PE?
IT consultant. Network manager. Packet junkie.
1-928-328-1509
normis
Re: IPv6 TODO
Thu Dec 30, 2010 10:37 am
no, stateless
yes, MPLS 6PE is planned, but probably in v6 beta only.
MCT
Re: IPv6 TODO
Thu Dec 30, 2010 11:02 am
IPV6 support is a top need right now.
TKITFrank
Re: IPv6 TODO
Thu Dec 30, 2010 2:09 pm
Will it include new things except just IPv6 support? Like ciphers, PFS Group 14-16 and authentication algorithms?
- Webproxy
Is it possible for you to add a remove button to remove all the "Mikrotik HttpProxy" headers while you guys are at it? ;)
MTCNA
"I don't believe UNIX is Utopia. It's just the best set of tools around."
fewi
Re: IPv6 TODO
Thu Dec 30, 2010 4:37 pm
- Hotspot
How? NAT64 -> NAT44?
Hooray, that's exciting. Excited about the other features, too.
Specific answers require specific questions. When in doubt, post the output of "/ip address print detail", "/ip route print detail", "/interface print detail", "/ip firewall export", and an accurate network diagram.
nz_monkey
Re: IPv6 TODO
Thu Dec 30, 2010 11:10 pm
Great news !
Thanks guys, looking forward to it.
http://thebrotherswisp.com/ | Mikrotik MTCNA, MTCRE, MTCINE | Fortinet FTCNA, FCNSP, FCT | Extreme Networks ENA
nz_monkey
Re: IPv6 TODO
Thu Dec 30, 2010 11:16 pm
I would like to suggest that when the dev team are concentrating on IPSEC that they implement "Virtual Tunnel Interfaces" and "Next-Hop Tunnel Binding" as well as IPv6
this would allow us to replace a large amount of aging Netscreen's and Juniper SSG's ;) It is also one of the top features requested on the Wiki list
fewi
Re: IPv6 TODO
Thu Dec 30, 2010 11:19 pm
VTIs would be awesome, yes.
roadracer96
Forum Veteran
Forum Veteran
Re: IPv6 TODO
Fri Dec 31, 2010 12:07 am
Cant really say you support IPv6 without IPSEC functional.. IIRC, the IPv6 RFC required IPSEC capability... ;)
So realistically, we are looking at about 12-18 months before ROS really supports IPv6 completely.
roadracer96
Forum Veteran
Forum Veteran
Re: IPv6 TODO
Fri Dec 31, 2010 12:10 am
Should also allow you to disable exposing the address of the device being proxied (X-Forwarded-For header).
normis
Re: IPv6 TODO
Mon Jan 03, 2011 7:47 am
so and where did you get that number?
nz_monkey
Re: IPv6 TODO
Mon Jan 03, 2011 11:27 am
lol, did the O/P not know the Latvian's work faster in the winter to keep warm ;)
IPv6 featureset will be complete in a jiffy
roadracer96
Forum Veteran
Forum Veteran
Re: IPv6 TODO
Mon Jan 03, 2011 3:14 pm
If you arent doing IPv6 IPSEC until V6, and v5 has been testing for 9 months, with a few months to go until stable.
Just sayin....
normis
Re: IPv6 TODO
Mon Jan 03, 2011 3:25 pm
we could make v5 full release in 2 months, and release v6 beta the day after that. just sayin
roadracer96
Forum Veteran
Forum Veteran
Re: IPv6 TODO
Mon Jan 03, 2011 5:44 pm
Beta != Release
normis
Re: IPv6 TODO
Tue Jan 04, 2011 8:02 am
Beta != Release
Release means when something is available to the public. How stable or complete that release is, is another question. As you know, versions keep changing, and new features get added since 1996, so there is not one "final" or "complete" version out there.
roadracer96
Forum Veteran
Forum Veteran
Re: IPv6 TODO
Tue Jan 04, 2011 6:23 pm
Beta != Release
That has to be the most narrow-minded comment I have ever seen. "RouterOS is never complete because we always add stuff to it".
If that is how you want to justify it, fine. But the simple fact remains that (unless someone kicks dev into gear) a complete IPv6 feature-set is 12-18 months away. Masquerading behind "We are always adding new features" wont change that.
normis
Re: IPv6 TODO
Wed Jan 05, 2011 8:27 am
I didn't say anything like that. I referred to the popular wish for "v5 final release". Use of word "final" is misleading, as you know v4.0 already superseded by 16 newer versions.
nickshore
Re: IPv6 TODO
Wed Jan 05, 2011 3:06 pm
Still no sign of IPv6 mangle mark routing ??? so still can't do nth load balancing
On that topic is there any chance we could have a very simple config like ECMP but which does per packet and not per session ???
It would just round robin the packets across each interface added to the default route.
Nick.
Nick Shore MTCNA MTCWE MTCRE MTCINE MTCTCE
LinITX.com - MultiThread Consultants
Get your MikroTik RBs and Training: http://linitx.com/brand/mikrotik
Official UK MikroTik Distributor
IRC chan: #routerboard on irc.z.je (IPv4 and IPv6)
butche
Trainer
Trainer
Re: IPv6 TODO
Fri Jan 28, 2011 10:27 am
This will help.
Will this be something that works for all address types or just link-local? If the MT is in router mode, wouldn't this break the specification? Or is this DHCPv6 client? I'm not complaining, but wanting to understand what you are saying.
YIPPEE!! One of the VERY important features.
Butch Evans
Mikrotik Certified Trainer
Mikrotik Certified Consultant
BLOG: blog.butchevans.com
http://store.wispgear.net/
flrichar
Re: IPv6 TODO
Fri Jan 28, 2011 1:46 pm
Hi guys!
I'm new to MikroTik but not new to networking or routers. I just want to say what a fantastic job you've done on the product. I purchased a RB750 last year sometime, and had tried it in different lab scenarios, and the other night I was ready for the real deal. I've also been lurking on the irc channel as flrichar.
The MT handles everything I need it to do, including my IPv6 tunnel from HE.net. I did notice whenever I enable stateless autoconfiguration, it doesn't seem to be sending router advertisements. Am I doing something wrong, or is this a bug or caveat? I'm running the latest stable 4.16. I've set it up before in Cisco and Linux, and actually, I've turned on radvd for the same /64 and segment I want, and it works perfectly.
I'm at the point where I don't mind if it's a bug or caveat, I just want to know I'm not crazy and stop pulling my hair out searching for something I may have overlooked!
:D
nickshore
Re: IPv6 TODO
Mon Jan 31, 2011 3:17 pm
Our ISP has just announced support for IPv6 Prefix Delegation on PPP using DHCPv6
http://www.aaisp.net.uk/news-2011-ipv6.html
How long until we see support for this in RouterOS ???
The more complete the IPv6 implementation, the more routerboards we will sell, the competition are lagging behind.
Nick.
thebp
Re: IPv6 TODO
Fri Feb 04, 2011 11:52 pm
A good question - I keep an eye on the changelogs, but it hasn't appeared yet. It's critical for me - my ISP does dual-stack V4/V6, and I'm unable to use IPv6 because the RB750 does not do DHCPv6/PD. My only option would be to pull the RB750 out and put the Cisco back in (with the corresponding increase in power bill).
I note in this (http://forum.mikrotik.com/viewtopic.php ... 0&start=50) thread there's discussion of this. themmc has the right idea. I saw the suggestions to statically configure prefixes for users - as themmc said, that does not work. If a user's PPP session can dynamically land on any of 3 or 4 different LNS's, which one do you hard code their prefix on?
For an ISP, they need tools to do this stuff dynamically. They have those - mostly.
For a user, they need a router than can do DHCPv6/PD. Those are few and far between.
As a side note, an RB750 that had an ADSL2+ port (and DHCPv6/PD) would be an interesting beast indeed.
omega-00
Re: IPv6 TODO
Thu Apr 14, 2011 7:02 pm
Whenever I'm having a bad day, I can just come here and read the IPv6 feature list to make me happy again.
Appreciation will be shown in love and alcohol. ^_^
brightwifi.com | mikrotik-routeros.com | MTCNA,MTCWE.MTCTCE | Give karma where due
Ozelo
Re: IPv6 TODO
Mon Apr 18, 2011 9:13 pm
Please consider a IPv6 blackhole implementation.
MTCRE - 1104RE006
MTCINE - 1104INE001
Sanity
Re: IPv6 TODO
Mon Apr 18, 2011 9:48 pm
Still no sign of IPv6 mangle mark routing ??? so still can't do nth load balancing.
I think whis will never make it to the TODO list...
...because in v5 Winbox I already see Ipv6 firewall mangling.
What about a NOT-IPV6 todo list? My wishlist:
* MLPPP, mostly PPPTP or anything else server AND client. Like so many I am using nth mangling to bundle connections which is very inflexible compared to MLPPP.
* Real, not bandwidth limited queues. Have the OS take from the highest priority queue first inthe tree, dont drop random packets for lower priority traffic. I never will understand why my PING drops when I backlock "left over" traffic on my connection. Others can do that (AVM does prioritization without knowing the netwok speed nicely).
* Integrate queues with MPLS in a sensible faction. At least allow requeueing on special MPLS queues (simple priority is all that is needed there, the priority can be set at the entry point). Right now I can not use MPLS becasue of traffic classes and the inability to mix priority + routing. PLEASE correct me if I am wrong ;)
Beccara
Long time Member
Long time Member
Re: IPv6 TODO
Tue Apr 26, 2011 2:13 am
Interesting point to note, Blizzard is rolling out IPv6 for WoW in tomorrows 4.1 patch. I believe the first major game to do so
themmc
Re: IPv6 TODO
Sat May 14, 2011 12:36 pm
Curious as to how DHCPv6 prefix delegation is going? Is that likely to be here soon?
omega-00
Re: IPv6 TODO
Sun May 15, 2011 2:58 am
Would be good to have prefix delegation out before world IPv6 day :-D
http://isoc.org/wp/worldipv6day/
Beccara
Long time Member
Long time Member
Re: IPv6 TODO
Sun May 15, 2011 11:38 pm
Good luck with that, looks like we will have to miss ipv6 day due to memory leaks in ROS 5.x
lavv17
Re: IPv6 TODO
Mon May 16, 2011 10:06 am
dynamic ipv6 address lists are really needed to implement rate limitation with pcq.
nickshore
Re: IPv6 TODO
Wed Jun 22, 2011 6:41 pm
Any updates on the following for IPv6 ??
Prefix Delegation
Packet Mangling
Policy Routing
How long until we have a complete IPv6 implementation ?
Nick.
ysam
Re: IPv6 TODO
Thu Jun 23, 2011 2:47 am
Hi there,
Normis can you confirm that you will be implementing http://tools.ietf.org/html/rfc6204 as a typical IPv6 CE Router?
thx
paoloaga
Re: IPv6 TODO
Tue Jun 28, 2011 10:29 am
I am impatient to see full IPv6 PPPoE-server support in ROS. I would allow me to throw away several ciscos.
lavv17
Re: IPv6 TODO
Tue Jun 28, 2011 11:20 am
It works here (ROS 5.4). I just miss dynamic ipv6 address-lists.
hci
Long time Member
Long time Member
Re: IPv6 TODO
Thu Jul 21, 2011 11:30 pm
Beccara
Long time Member
Long time Member
Re: IPv6 TODO
Mon Jul 25, 2011 6:43 am
DHCPv6-PD is fast becoming the most critical feature missing from ROS, The only reason I can see that it hasn't been added yet is MT simple aren't putting any energy into IPv6. I think it's time (again! since things seem to happen only when we kick up a fuss) to all e-mail MT support about DHCPv6-PD and other key IPv6 features
omidkosari
Trainer
Trainer
Re: IPv6 TODO
Mon Jul 25, 2011 9:08 am
I agree . unfortunately other solutions have no success also http://forum.mikrotik.com/viewtopic.php?f=15&t=53586
MTCNA , MTCRE, MTCWE, Mikrotik Certified Trainer
nz_monkey
Re: IPv6 TODO
Tue Jul 26, 2011 6:52 am
Maybe Mikrotik are waiting for 6.0beta to introduce more ipv6 functionality... ??? ;)
normis
Re: IPv6 TODO
Tue Jul 26, 2011 7:58 am
we are working on it
Beccara
Long time Member
Long time Member
Re: IPv6 TODO
Tue Jul 26, 2011 8:44 am
You've been "working on it" for 6+ months now, It's a joke. Atleast just take some OSS code and whack a npk together.
Given the prevalence of PPP for internet connection the IPv6 stack in ROS is pretty useless without PD, You can work around it using 6to4 tunnels over your access network but that doesn't scale well enough.
How about you actually hand out a realistic time frame this? You said ROS 5 would have it but that could be a year away still, It's not a massive under taking. It seems like you've slipped back into your old habbit of doing nothing until your users scream at you for something
paoloaga
Re: IPv6 TODO
Thu Jul 28, 2011 12:34 am
Can you pass IPv6 network routes to attached PPPoE clients assigned through Radius?
lavv17
Re: IPv6 TODO
Thu Jul 28, 2011 10:57 am
Yes, with Framed-IPv6-Prefix. They stuck in ospf, though, Ticket#2011051866000501.
paoloaga
Re: IPv6 TODO
Fri Jul 29, 2011 8:01 pm
Ok I will make some test in the next days. Are you planning to fix the OSPF issue in the next release?
Otherwise I might consider using BGP to announce routes to the rest of my AS.
Thanks! :-)
normis
Re: IPv6 TODO
Fri Sep 23, 2011 1:15 pm
- IPsec IPv6 support with IKE v2 IKE v3 (probably in v6 beta) - DONE
- IP Pool support; for PPP and DHCP (to manage networks instead of addresses) - DONE
- IPv6 Address auto-configuration from other routers - hopefully next week
- IPv6 DHCP prefix assignment - DONE
- Hotspot
- Webproxy
- DNS64
- NAT64
- SSTP IPv6
- MPLS
nickshore
Re: IPv6 TODO
Fri Sep 23, 2011 2:05 pm
what about IPv6 Firewall route marking for nth mangle etc ?
janisk
Re: IPv6 TODO
Fri Sep 23, 2011 2:12 pm
IPv6 policy routing is planned for later, no actual plans yet.
yogii
Re: IPv6 TODO
Fri Sep 23, 2011 3:22 pm
me too, very need it, thanks mr.janisk, thanks mikrotik. :) i hope ipV6 policy routing will release immediately.
Jeeves
Re: IPv6 TODO
Mon Oct 31, 2011 4:48 pm
BTW: I've got a working DHCPv6 on Mikrotik now. All I need for it is support for Radius. Can't really tell who gets which prefix now.
Chupaka
Re: IPv6 TODO
Mon Oct 31, 2011 7:32 pm
yep, RADIUS support is 'must have' feature for DHCPv6!
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
TKITFrank
Re: IPv6 TODO
Tue Nov 15, 2011 4:32 pm
Mr Normis what is the current status? how many % finished? :)
- Hotspot
- Webproxy
- DNS64
- NAT64
- SSTP IPv6
- MPLS
MTCNA
normis
Re: IPv6 TODO
Wed Nov 16, 2011 12:00 pm
which of these do you personally need the most? others also, please discuss
we are working on:
- SSTP IPv6
- MPLS
- Webproxy
I think this already works
TKITFrank
Re: IPv6 TODO
Wed Nov 16, 2011 4:00 pm
Hi Normis,
@home where I currently do this to experiment and learn IPv6.
Well the thing I was trying to do right now is to create ACL's in the webproxy and to get that to work properly. I can not add IPv6 addresses in the ACL in winbox.
I have in IPv4 also used the webproxy in transparent mode. Seems to be impossible right now and from what I can read about IPv6. Am I wrong?
@work we currently have IPv6 on the roadmap for next year.
The things we need there is L7 filtering, Hotspot, DHCP (Equal function as IPv4, not only prefix delegation) and MPLS
How far is your progress on these things? :)
edit: I tried to use the proxy by hardcoding it in firefox and made a test rule to allow all. But to no avail it did not allow me to use IPv6 and the webproxy. Could be user error but I can not at the moment figure it out. Anyhow ACL with IPv6 address or subnet does not work. Will be translated to 0.0.0.0 when done with Winbox Terminal. And not accepted when done in the GUI.
MTCNA
lavv17
Re: IPv6 TODO
Thu Nov 17, 2011 12:49 pm
I need dynamic "ipv6 firewall address-list", currently it's only static.
Also ospf-v3 is not quite stable, there are stuck redistributed routes.
Users browsing this forum: No registered users and 87 guests
