eghtedari2000
separate netwoks
Thu Jan 06, 2011 3:23 pm
hi
i have 2 range of ip
172.17.5.0/24 and 192.17.6.0/28
i want to mangle these, can you please say me in source address with which character , i can separate them form together?
thanks
sergejs
Re: separate netwoks
Thu Jan 06, 2011 3:27 pm
1) Use address-list, if you need one mangle rule for both subnets.
Add both networks to /ip firewall address-list, set one mangle rule with src-address-list.
2) Create two mangle rules with the same mark-connection/mark-packet.
eghtedari2000
Thu Jan 06, 2011 3:33 pm
i know
but i wanted to know in source address i separate them with comma, or dash or ...?
sergejs
Thu Jan 06, 2011 3:37 pm
You can use only range there,
ip firewall mangle add src-address=
SrcAddress ::= [!]Range
  Range ::= A.B.C.D[-A.B.C.D |0..32 |/A.B.C.D ]    (IP address range)
To use one mangle rule for both networks, use address-list.
eghtedari2000
Thu Jan 06, 2011 3:39 pm
can you type the sample for me with my ip addresses that i said in top, and the way that i should type in GUI?
also i think press ! beside ranges
thanks
fewi
Thu Jan 06, 2011 4:01 pm
add list=whatever address=172.17.5.0/24
add list=whatever address=192.17.6.0/28
/ip firewall mangle
add chain=prerouting action=accept src-address-list=whatever
Paste that into the terminal window of the GUI and then inspect the things the commands created in the GUI to figure out how to create others like them via the GUI.
Specific answers require specific questions. When in doubt, post the output of "/ip address print detail", "/ip route print detail", "/interface print detail", "/ip firewall export", and an accurate network diagram.
eghtedari2000
Fri Jan 07, 2011 8:05 am
/ip firewall mangle
hi, thanks alot, good way.
can you please say me in one mangle rule, how can i put more than 1 protocol, for example, both gre and ipsec and tcp?
thanks
negge
Fri Jan 07, 2011 3:10 pm
You can't. You will need one rule per protocol. Just copy a previous rule then change the protocol type and you'll be fine.
Users browsing this forum: No registered users and 44 guests
