emsi
Clear user command history
Tue Jan 18, 2011 4:02 pm
is there any way clearing the command history of a user? We used the "/tool fetch" command on a customers router which expects the password as a clear text parameter. Now we have it in the cli history (up arrow) and can't get it out from there! ;-) Workaround would be adding a new user with "full" group permissions and hand the new username out to the customer. Afterwards delete the old one. That works. Any other ideas?
thanks
Oliver
sergejs
Re: Clear user command history
Wed Jan 19, 2011 4:52 pm
As far as I know it is not possible.
dssmiktik
Forum Veteran
Forum Veteran
Wed Jan 19, 2011 11:43 pm
Maybe an added feature (requiring the full user permission) ?:
[/system console reset-command-history]
Doug
normis
Thu Jan 20, 2011 8:46 am
that's why first make another admin user, then do the private stuff from there.
emsi
Thu Jan 20, 2011 3:43 pm
I will next time! ;-) Is there any technical reason why RouterOS behaves like this? Every router hardware I know deletes the history after reboot. Keeping the history is a good thing, but there should be a way to clear it. If this is not a big deal take it as a "feature request".
thanks
Oliver
jo2jo
Forum Veteran
Forum Veteran
Sun Dec 18, 2011 12:42 am
You will see this is very common, in stead of addressing the issues MT will give some crazy work around that does not directly address you issue, but is enough to keep you quite for now.
SO no they do NOT feel like coding this feature many people on this board have asked for.
sad
:beep :beep :beep
dssmiktik
Forum Veteran
Forum Veteran
Sun Dec 18, 2011 7:51 am
I think it would be fairly trivial to do, maybe:
echo > /path/to/history/file
Doug
cartes
Wed Dec 21, 2011 2:19 am
I think this is a very critical issue here. We were doing some digging, and found that this is not possible at all. Even if we create another user, as suggested by sergejs, any command line history still stays in memory, and returns once the user is recreated, even after reboots!
We were creating an in-house system to intelligently manage large number of Mikrotik Routers on customer premises, but if there is no way to delete history, then this is a major issue.
Please advise!
bluecrow76
Mon Feb 06, 2012 9:29 pm
I'm gonna give this a big bump!
I find it easier to create new users from the command line, but I don't do it anymore because the password that is set is in plain text in the history. Not good when there's no way to clear it!
Shouldn't be that difficult to add /system history clear...
bkus
Sun Aug 25, 2013 8:37 pm
Has this feature been added yet? It's really critical for security.
jandafields
Wed Aug 28, 2013 6:27 am
I also vote to have this security problem fixed. Creating a new user does not clear the history.
normis
Wed Aug 28, 2013 9:59 am
we have added history clear command in next RouterOS v6.3
tomtom80
Wed Aug 13, 2014 9:33 am
Is this feature now from version 6.3 included? When yes how is the command?
patrikg
Wed Aug 13, 2014 12:29 pm
clear-history -- clear command history for all users
ros code
[admin@demo2.mt.lv] > console clear-history
Users browsing this forum: andriys, petertosh, wispmikrotik and 60 guests
