manuelritter
PPPoE IP Pools from Radius
Tue Jan 25, 2011 5:02 pm
Is there any way to get pppoe ip pools from radius server?
We use freeradius and it would be much easyer than configure for each router manualy
Greetings
Manuel
SurferTim
Re: PPPoE IP Pools from Radius
Tue Jan 25, 2011 5:04 pm
"Framed-Pool" is what I use with the hotspot and FreeRADIUS to assign an ip pool.
manuelritter
Tue Jan 25, 2011 5:45 pm
What i understand from Framed-Pool is, that i could give the name of a pool already created on the router, right?
Or is there any other way?
Greetings
Manuel
SurferTim
Tue Jan 25, 2011 6:17 pm
It does depend on the ip pool name assigned on that router. But that does not limit the ip range. The same ip pool on two different routers could be different ranges.
There is "Framed-IP-Address", but that is much more specific.
m4rk0
Wed Jan 26, 2011 11:42 pm
Greetings
Manuel
It's impossible, AFAIK :)
http://www.mreza-wisp.ba/
Please, give Karma if I fix your problem
Certified MTCNA
Muqatil
Trainer
Trainer
Fri Jan 28, 2011 4:05 pm
It is possible Using FreeRADIUS.
Check the module radippool
You can use a mysql database to store the ip to distribuite.
I've 60 PPPoE servers (one on each AP) on my network, synced by FreeRADIUS.
You have to tune it a bit to avoid IP collisions, but it works, and it works PERFECTLY.
I even choose which range of IP assign to specific PPPoE Servers, when those IP are all busy, FreeRADIUS assigns other available IPs.
Renato Bernardi
skype: medtech5
nxl
Tue Oct 18, 2016 1:27 am
How do you tune it? Details are appreciated. Thanks.
Users browsing this forum: Bing [Bot], mkx, omnet, shimal, xvo and 121 guests
