MUM Europe 2020
otgooneo
Trainer
Trainer
How to graph mangle rule rate
Tue Jan 25, 2011 5:28 pm
Hello guys,
I have ROS v5.0 and I created some mangle rules. I can see the real time rate graphic using winbox but I need to store this graphic. Please help me to do that. Using SNMP, Dude or traffic flow?
Want to learn more and more...
sergejs
Re: How to graph mangle rule rate
Wed Jan 26, 2011 9:59 am
Create queue (it could without limitation) and make graph for it.
otgooneo
Trainer
Trainer
Fri Jan 28, 2011 9:48 am
Thank you Sergejs. Upload traffic is okay. Download traffic is not right. Please see the attached picture. Mangle is working fine, but queue can`t catch marked packets.
[otgonkhuu@MobiNetAU] > ip firewall mangle print where comment="ExtDownlink"
 0   ;;; ExtDownlink
     chain=postrouting action=mark-packet new-packet-mark=Download-Garts passthrough=yes src-address-list=!OTHERISP dst-address-list=LOCAL
[otgonkhuu@MobiNetAU] > queue simple print where name=External-Download
 0    name="External-Download" dst-address=0.0.0.0/0 interface=ether1 parent=none packet-marks=Download-Garts direction=both priority=8 queue=default/default
      limit-at=0/0 max-limit=0/0 burst-limit=0/0 burst-threshold=0/0 burst-time=0s/0s total-queue=Test-Gueue
Strange that gueue doesn`t work. I tried to change Chain=forward and priority=1
sergejs
Fri Jan 28, 2011 3:56 pm
Set interfaces=all to your /queue simple.
otgooneo
Trainer
Trainer
Wed Feb 02, 2011 12:11 pm
Thank you Sergejs. Now I can see all download and upload. But gueue graphic is always less than mangle rule graphic. What can I do for fix it. Difference between gueue and mangle graphic is 3Mbps to 8Mbps.
Caci99
Wed Feb 02, 2011 4:31 pm
I see that your queue is grabbing packets in TX and RX. Looks like the summ of them equals, more or less
those of your mangle queue. I think the queue will reflect the quantity of rate of the mangle a little bit later
than the rate you see in the mangle itself.
-Toni-
Don't crash the ambulance, whatever you do
otgooneo
Trainer
Trainer
Mon Feb 07, 2011 7:58 am
Thank you for reply. I will try again.
Sergejs... Can I graph /queue simple print count-only ? It means I want to graph active users.
otgooneo
Trainer
Trainer
Mon Feb 07, 2011 12:54 pm
Today I found mistake. No way to use queue for graphing. When I was added unlimited simple queue for graphing, all my PPPoE clients dynamic queues was stopped. Hotspot client dynamic queues are working fine. So I have disabled this simple queue today.
It is was very big mistake. Best choice is add feature to store graphic of Mangle rules.
Users browsing this forum: No registered users and 41 guests
