MUM Europe 2020
proweb
[REQ]HELP config Transparant Web-proxy
Wed Oct 12, 2005 10:41 pm
Thanks man
boardman
Try this
Thu Oct 13, 2005 12:41 am
/ip firewall nat add in-interface=PUBLIC dst-port=80 protocol=tcp action=redirect to-ports=3128 chain=dstnat
assuming your webproxy is up and running in port 3128 with transparent mode enabled, replace the PUBLIC for your actual interface name.
Hope this help.
Best
Jorge
proweb
Please give me input and the way out....
Thu Oct 13, 2005 12:50 am
Thanks man
boardman
try this
Thu Oct 13, 2005 1:16 am
your web-proxy conf looks good, but leave the src-address: 202.22.90.44
blank.
and
If you are using mikrotik version 2.9.x just do the following and it will work:
/ip firewall nat add in-interface=ether1 dst-port=80 protocol=tcp action=redirect to-ports=3128 chain=dstnat
if you are using 2.8.X do a DST-NAT rule as you did it -->
add in-interface=ether1 protocol=tcp \
dst-address=!192.168.0.2/32:80 action=redirect to-dst-port=8080
BUT WATCH OUT YOU ARE REDIRECTING TO PORT 8080 AND YOR WEB-PROXY IS RUNNING IN PORT 3128 !!!!!!
Hope this help...
Best
Jorge
proweb
Re: try this
Thu Oct 13, 2005 1:32 am
Thanks man
proweb
Thu Oct 13, 2005 2:37 am
I want to like this bagan
Internet ---> [Ip Public]Mikrotik[Ip Local] ----> Clients
[Proxy Transparant-Bandwitdh Limitting]
I set My computer :
How bout MT 2.8.6 to built MRTG?? Please helpp me
proweb
[REQ]Please Help Me...to setup Web-Proxy Transparant
Thu Oct 13, 2005 2:38 am
Still strezzz
boardman
mmmm
Thu Oct 13, 2005 3:10 am
Ok, I guess I am starting to understand what you want......
You want to block porno-offensive sites and also display a deny page....
Ok I did that once, but I left it aside because those test were made at the time when mikrotik was version 2.X and I was unable to properly control the bandwidth .... but anyway here is what you need.
You need a linux box with fedora or redhat or the flavor you like most.....
In that box configure the following:
- Firewall
- Squid
- Dansguardian
The idea is this can be little offset has been a long time since then...., in your mikrotik activate parent proxy and point that to the ip of your linux box, ...
Your linux box will proxy thru squid(webcache) and dansguardian(filter).... there is a lot of info in the web for this matter. And probably you can also add clamantivirus to your filtering deployment.......
By the way... be carefull the "engine" of your linux box has to be capable of handling all that work...... Lots of RAM and fast harddrive....!!!
Best
Jorge Boardman
http://www.laredonet.com
http://www.laredonet.net
http://www.boardman.com.mx
http://www.autophone.net
Users browsing this forum: faxxe, MSN [Bot] and 95 guests
