skachy
disable web interface
Mon Feb 14, 2011 11:46 am
Hello
Can I somehow disable Mikrotik web interface ?
thanks
Jakub
jtroybailey
Re: disable web interface
Mon Feb 14, 2011 11:54 am
add action=drop chain=output disabled=no protocol=tcp src-port=80
give that ago
skachy
Mon Feb 14, 2011 12:02 pm
thanks, but I have got a web server behind, so this will block all the traffic on port 80, which is not exactly what I want. Or not ?
J.
kirshteins
Mon Feb 14, 2011 12:05 pm
Chain=output will only affect traffic issued from the router, not a traffic going through the router.
skachy
Mon Feb 14, 2011 12:17 pm
ok, thanks a lot !
Jakub
huntah
Mon Feb 14, 2011 1:00 pm
You could also disbale WEB in IP/SERVICES ...
seems simpler :)
Huntah
asad
Thu Dec 20, 2012 9:11 am
If we disbale WEB interface in IP/SERVICES. then can we access router from winbox or not...
skot
Long time Member
Long time Member
Thu Dec 20, 2012 10:29 pm
Yes, you can still access router from Winbox if you disable WWW, which are separate services.
I don't need any karma... I have Ιησους Χριστος!
shivapm
Fri Jul 22, 2016 8:57 am
thanks for providing the information about blocking access to web interface of router.I have a question can we allow certain ip to allow access to web interface.thanks.
cutedrummerboy
Fri Jul 22, 2016 9:57 am
i can see there is an available from column. use it.
Device: RB2011UIAS-RM, RB750GL, CISCO SG300-28, UNIFI UAP-LR
shivapm
Sun Jul 24, 2016 7:07 am
could you please provide information in detail.
Users browsing this forum: anav, eworm, hgoertz, titinas and 130 guests
