joie
Route internal subnet to locally assigned public subnet
Sun Feb 27, 2011 10:08 am
I've got an internal 192.168.1.X/24 subnet with 192.168.1.1 as the gateway and an external 204.228.X.X/29 public subnet with web and email ports dst-nat to local IP's. I masquarade my internal subnet to the internet and all works well except it also masquarades my internals to the nated IP's, so all my internal PC's show up as 192.168.1.1 in the server log files. If I connect to www.domainname.com from an internal PC with IP 192.1689.1.100 and then go look at the log files on the server it shows the connection is from 192.168.1.1. Is there a way to bypass maquarade and route the internal 192.168.1.X/24 to the public IP's so that the PC's will show there local IP in the server log files and not the masquaraded IP.
fewi
Re: Route internal subnet to locally assigned public subnet
Sun Feb 27, 2011 6:50 pm
No, unless you connect to the inside IP directly (which you aren't if you connect by DNS names resolving to public IPs$.
http://wiki.mikrotik.com/wiki/Hairpin_NAT
Specific answers require specific questions. When in doubt, post the output of "/ip address print detail", "/ip route print detail", "/interface print detail", "/ip firewall export", and an accurate network diagram.
vlad8
Mon Feb 28, 2011 2:54 pm
you could assign public ips to internal servers instead of doing dst-nat
joie
Tue Mar 01, 2011 6:48 am
Well damn.
I had tried everything I could think of so I figured it wasn't possible but I was hoping I'd overlooked something.
Vlad, More servers than IP's plus even if I had an IP per server I'd still NAT for the firewall.
Thanks for the response guys.
vlad8
Wed May 18, 2011 6:24 pm
if you have public ips on each server there's no reason why you'd masquerade them...
NAT and firewall filter don't need eachother to run
Users browsing this forum: No registered users and 145 guests
