MUM Europe 2020
skydragon
PPPoE Server CPU Optimizing
Thu Mar 03, 2011 1:10 pm
I have R493AH with routerOS 5.4
I have 8 PPPoE servers rununing on the router and i have 150 PPPoE users and might be rise to 300+ users.
the cpu usage is 80% to 100% :(
i like advice how to lower my cpu usage, or any other solutions might be helpful
thank you
martini
Re: PPPoE Server CPU Optimizing
Thu Mar 03, 2011 8:32 pm
use PC server for PPPoE, core2duo or core2quad with intel ethernet
marekm
Fri Mar 04, 2011 12:11 am
Single-core Pentium III 1400MHz with rtl8139 ethernet works fine here for ~100 PPPoE connections (and lots of other things), running Debian but with rp-pppoe rebuilt to upgrade 3.8 to 3.10 and enable kernel mode PPPoE (stock package runs user mode only, more CPU load). Not sure which mode (kernel or user) and rp-pppoe version is used in ROS, it would be nice to know. In some situations you just can't use a PC due to space/power/noise constraints.
hedele
Fri Mar 04, 2011 2:22 am
Disable conntrack if you don't need it
Rework your queueing system, if you are using it
rework your firewall rules...
... the usual stuff ;)
Users browsing this forum: Amakesh, hubipuli, Sanalturkey, w32pamela and 98 guests
