MUM Europe 2020
chvdr
pcq config: pcq-limit and pcq-total-limit settings - how to
Wed Mar 16, 2011 10:33 am
Hello friends,
I just wonder how to tune-up my pcq configuration. Bad working pcq-rules depending of "pcq-limit" and "pcq-total-limit" values.
I've read wiki pages, Megis' howto, and everything posted on the forum, that can be found.
For example, let us consider downstream limitation of "VIP" customers on the router such as follows:
name="VIP_down" kind=pcq pcq-rate=40000000 pcq-limit=40
pcq-classifier=dst-address pcq-total-limit=50000
In the mangle one C-class network marked as VIP. Actually 40 customers worked there. If pcq-total-limit set to 2000 or 5000 actual traffic shaped to 5Mbps each VIP customer. If 50000 - to 10-12Mbps.
What is the right compute algorithm to set right values to the traffic shapers. I want to set 60 customers to work to maximum 40Mbps with such queue.
Best regards,
C. G.
If nothing to say, do not say anything...
All thoughts that have huge effect actually are simple...
fewi
Re: pcq config: pcq-limit and pcq-total-limit settings - how
Wed Mar 16, 2011 3:02 pm
pcq-limit is how many packets can be held up in the queue per dynamic sub-queue. When the queue is full and the rate limit is still being exceeded packets are dropped. 50 is a pretty good value. pcq-total-limit should simply be the pcq-limit multiplied by the number of users you expect to simultaneously cause traffic.
Specific answers require specific questions. When in doubt, post the output of "/ip address print detail", "/ip route print detail", "/interface print detail", "/ip firewall export", and an accurate network diagram.
chvdr
Wed Mar 16, 2011 4:23 pm
thank you
Best regards,
C. G.
deejayq
Sat Apr 23, 2011 1:31 am
from my experience when setting pcq-limit to 50 i get about 1.2MBps speed, at about 150 i get about 1.8MBps speed
Chupaka
Sat Apr 23, 2011 11:24 am
on what version? in ROS v5 PCQ was a bit rewitten =)
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
chvdr
Sat Apr 23, 2011 3:21 pm
could you tell us what is on v5
Regards,
Chavdar
Best regards,
C. G.
Chupaka
Sun Apr 24, 2011 12:12 am
Users browsing this forum: marek263, rioven and 60 guests
