elgo
OS v5.0 - VLAN bugs - No GO
Sun Apr 03, 2011 1:55 pm
My 450G is fully operationnal with 4.17.
This are 3 problems that prevent my board to be operationnal on 5.0:
  1. cant modify switch-all-ports, answer is "mirror-source does not belong to switch", and "none" isnt recognized, so that if you define a valid interface there, you wont be able to "undo". Bugs not there on v4.17.
  2. pppoe-client (over a vlan on an ether1 non switched interface) isnt working anymore. I get this during past hour:
    02:20:00 pppoe,ppp,info pppoe-fibre: initializing...
    02:20:00 pppoe,ppp,info pppoe-fibre: dialing...
    02:20:03 pppoe,ppp,info pppoe-fibre: terminating... - disconnected
    02:20:03 pppoe,ppp,info pppoe-fibre: disconnected
  3. vlan secure mode is quite borked: vlan-id 0 has to be set, ok I've seen this on wiki, but the cpu port isn't recognized anymore as a valid port for declaring vlan 0:
    set ports=cpu numbers=0
    port does not belong to switch
    It's not a problem unless you have a master port in your interfaces list... which is my case of course.
    Even with cpu port declared (like when migrating from 4.17 where it was operationnal), ports concerned by master-port setup aren't operationnal.
    What confirms that cpu port is involved and not taken in account is this:
    interface ethernet switch host print
    Flags: D - dynamic, I - invalid
     #   SWITCH                                              MAC-ADDRESS       PORTS                                              TIMEOUT DROP MIRROR VLAN-ID
     0 D switch1                                             3E:2D:A1:BC:94:DA ether3-LAN                                         2m30s   no   no
     1 D switch1                                             00:0C:42:7F:40:75 (unknown)                                          2m      no   no
5.0 went stable, ahem...
Bug 1 was there since last RC (which was the first I tried back then).
I revert to v4.17.
RB450G - OpenWrt (so much more stable than with routerOS)
-> now: UBNT EdgeRouter Lite
(very unlikely to be MT customer again in the future)
elgo
Re: OS v5.0 bugs still around - No GO
Mon Apr 04, 2011 6:33 pm
Well, after thinking a bit, there may not be any pppoe-client related problem, if it's simply VLAN management by cpu port which is deficient.
Both problems may have the same cause.
Jeroen1000
Re: OS v5.0 - VLAN bugs - No GO
Mon Apr 04, 2011 10:21 pm
bug has been mentioned here also: http://forum.mikrotik.com/viewtopic.php?f=2&t=49810
I'm sure there will be a fix. Any time frame on this?
kirshteins
Tue Apr 05, 2011 9:17 am
We are looking into these problems. Thank you for the report.
willy
Tue Apr 05, 2011 10:01 am
Hello!
Krishteins: i received a mail from you about 3 weeks ago with same content. What is the state of this bug?
kirshteins
Tue Apr 05, 2011 3:32 pm
Hello!
This bug is fixed. Currently it needs to be tested internally. This issue will be resolved in v5.1.
elgo
Tue Apr 05, 2011 4:56 pm
Hello!
Thanks for this clear status report.
Should I open a separate thread for the switch bug on "switch-all-ports=yes/no" command?
kirshteins
Wed Apr 06, 2011 8:10 am
We are aware of this bug as well. It will be fixed in next release.
zervan
Thu Apr 07, 2011 10:27 am
Maybe my problem is related: Since 5.0 on RB750G I can't add static MAC to switch port (Switch - Host - New Switch Host), neither modify previously set hosts, this error appears: Couldn't add New Switch Host - vlan-id not supported for this switch (6)
I don't use any VLAN. Could you check it please?
Dusan Zervan from Slovakia
MTCNA, MTCRE
kirshteins
Thu Apr 07, 2011 2:02 pm
Thank your for the report. It seems like Winbox bug. Works fine from terminal.
elgo
Fri Apr 08, 2011 5:18 pm
No reference to the 2 bugs mentioned in my OP in 5.1 changelog, is it normal?
Fixes were postponed to 5.2?
mrz
Fri Apr 08, 2011 5:27 pm
those bugs should be fixed in v5.1
willy
Fri Apr 08, 2011 7:43 pm
WARNING! Please DO NOT install 5.1 if you have Atheros-8316 switch chip in use!
Board ssh communication stopped immediately after you type "interface ethernet switch p" (not able to write after to terminal) (issued on p as port or print, and h as host)
(winbox works)
zervan
Fri Apr 08, 2011 10:31 pm
Adding static MAC to switch port using WinBox now works in 5.1, thanks!
MTCNA, MTCRE
elgo
Re: rOS v5.0 - VLAN bugs - No GO
Sat Apr 09, 2011 7:16 pm
(winbox works)
Does this SSH problem only occurs during update or does it persist after a reboot or more of the router?
I'm not too concerned about webfig being broken on 5.1 (I only use CLI), but if working with CLI through SSH is not reliable, I still can't reasonnably upgrade from rOS 4.17 :/
Jeroen1000
Sat Apr 09, 2011 9:48 pm
Is the VLAN-bug fixed now? I see no mention of it in the ROS 5.1 changelog.
elgo
Sun Apr 10, 2011 2:46 am
kirshteins
Mon Apr 11, 2011 8:46 am
(winbox works)
I cannot reproduce this problem. Is there any addition actions to trigger this problem. What is the configuration in those sections?
Fatum
Mon Apr 11, 2011 12:24 pm
(winbox works)
I have this same problem (and more with switch chip)
Ticket#2011041166000202 (with supout.rif from 5rc10 - last working for me)
willy
Mon Apr 11, 2011 1:34 pm
(winbox works)
Are you serious? I reset board configuration to default to check this problem exists. The result: problem exists if board in defconfig. How to prove it?
kirshteins
Mon Apr 11, 2011 2:03 pm
Can you reproduce this problem on all ethernet interfaces?
Fatum
Mon Apr 11, 2011 2:17 pm
system reset-configuration keep-users=no no-defaults=yes skip-backup=yes
RS232:
[admin@MikroTik] > interface ethernet switch p
Hangs
Reset and Winbox
Hangs (CPU 100%)
Also can't login using serial port (hangs)
kirshteins
Mon Apr 11, 2011 3:34 pm
Please check with Winbox, perhaps there is still some configuration in switch section. Also you can try to Netinstall this board.
willy
Mon Apr 11, 2011 5:12 pm
Heh? I collect all 5.0 upgraded device from my network and do netinstall with all?
I try reset again. Now same state. After reset no config under switch (collect data via winbox) only 2 dynamic host in host table 1 in a ether interface (winbox desktop mac)
and another on UNKNOWN interface (it may be this is the switch-cpu interface, but named (unknown) This problem also found this report my previous ticket)
elgo
Mon Apr 11, 2011 5:27 pm
only 2 dynamic host in host table 1 in a ether interface (winbox desktop mac) and another on UNKNOWN interface (it may be this is the switch-cpu interface, but named (unknown)
Yeah, I'm thinking about this too, I observed that in v5.0.
kirshteins
Tue Apr 12, 2011 9:03 am
It might be useful to test Netinstall with just single device. Currently the cause of this problem is unknown and we cannot reproduce it locally. What is switch-all-ports status if you look from Winbox?
willy
Tue Apr 12, 2011 4:28 pm
Hello!
If possible i give you a humble advice: i send this device supout 4.17 and 5.0rc11 and 5.0, if im not wrong you can install exactly same device and config from this supout.rif, if you install this to rb750G and upgrade to 5.1 must see the problem, if problem related to configuration. But in forum many people with many boards crash with export interface ethernet switch. Maybe the problem common problem..
Your question:
In default the switch all port switched off by default and see this in winbox. Try switch on, but problem same.
Users browsing this forum: fs0c13ty, jlp16400, pe1chl and 94 guests
