mshoja65
Configure RB-750G as Layer3 Switch
Thu Apr 07, 2011 11:01 am
Hello All,
I'm beginner to mikrotik and i want to configure RB-750G as a layer Switch, so that can manage both routing & switching together with VLAN.
I have 3Mb bandwidth and 64 Valid IP (75.175.161.73/26) and 3 user, that i want to manage them like this.
User#1: BW=1024 IP Range= 75.175.161.73 255.255.255.248 (Ethernet#2)
User#2: BW=1536 IP Range= 75.175.161.81 255.255.255.240 (Ethernet#3)
User#3: BW=512 IP Range= 75.175.161.97 255.255.255.248 (Ethernet#4)
what should do and how can i start?
I will appreciate your help and attention.
dejanb
Re: Configure RB-750G as Layer3 Switch
Thu Apr 07, 2011 11:39 am
Hello friend!
I need more informations about your problem:
How do you plan to connect users? via wireless, cable...?
What kind of internet connection you are getting from your ISP?
Regards!
mshoja65
Thu Apr 07, 2011 11:45 am
Thank's a lot for your attention.
Via cable.
Direct Cable.
dejanb
Thu Apr 07, 2011 12:09 pm
Via cable.
Direct Cable.
Ok,
So, You are connecting users directly from lan ports of RB750?
You can create PPPoE server with rate limits for each user on RB750 easily to acomplish your task.
Regards!
mshoja65
Thu Apr 07, 2011 12:14 pm
Yes they are.
So there is no need to configure vlan?
another solution except PPPOE?
dejanb
Thu Apr 07, 2011 12:19 pm
Yes they are.
You can use private IP's on client LAN card, and then netmap it to Public IP on the Mikrotik, or you can create some kind of DHCP server, which will assign public ip address to clients...
There is no need to configure VLANs.
For me, best solution is to use PPPoE, it have many advantages...
Regards!
Users browsing this forum: altermeinhausbrennt, Infatuas, jebz, robertkjonesjr, sfrode and 54 guests
