MUM Europe 2020
arpadffy
in v5.0 routing mark not respected
Fri Apr 08, 2011 12:43 am
earlier using 5.0b9 this worked and after upgrading to 5.0 release I experience problems with respecting routing marks while choosing the gateway.
[admin@MikroTik] > ip firewall filter print
 0   ;;; default configuration
     chain=input action=accept protocol=icmp
 1   ;;; default configuration
     chain=input action=accept connection-state=related
     in-interface=ether1-gateway
 2   ;;; default configuration
     chain=input action=accept connection-state=established
 3 X ;;; default configuration
     chain=input action=drop in-interface=ether1-gateway
 4   chain=input action=accept connection-state=established
     in-interface=pppoe-out1
 5   chain=input action=accept connection-state=related in-interface=pppoe-out1
[admin@MikroTik] > ip firewall nat print
     chain=srcnat action=masquerade out-interface=ether1-gateway
 1   chain=srcnat action=masquerade out-interface=pppoe-out1
[admin@MikroTik] > ip firewall mangle print
 0   chain=prerouting action=mark-routing new-routing-mark=smtp passthrough=no protocol=tcp
     in-interface=ether2-local-master dst-port=25
 1   chain=postrouting action=log routing-mark=smtp routing-table=main out-interface=pppoe-out1
     log-prefix=""
 2   chain=postrouting action=log routing-mark=smtp routing-table=main out-interface=ether1-gateway
     log-prefix=""
[admin@MikroTik] > ip route print
 0 ADS  0.0.0.0/0                          81.231.248.129     1
 1  DS  0.0.0.0/0                          146.172.65.24      1
 2 ADC  81.231.248.128/25  81.231.248.177  ether1-gateway     0
 3 ADC  146.172.65.24/32   84.218.23.142   pppoe-out1         0
 4 ADC  192.168.10.0/24    192.168.10.1    ether2-local-ma... 0
[admin@MikroTik] > ip route rule print
Flags: X - disabled, I - inactive
 0   routing-mark=smtp interface=pppoe-out1 action=lookup table=main
...and anyway the correctly marked package leaves the router on ether1-gateway and not on pppoe-out1.
Any help would be appreciated.
Thank you in advance.
Regards,
Z
parsiansystem
Re: in v5.0 routing mark not respected
Fri Apr 08, 2011 9:11 am
hi...
i have the similar problem
then i get that the v5.0 is it stable!
then upgarde ro v5.0rc11
all of the problem solved!! 8)
good luck
Babak Mohammadpour
Manager of Technisions in ISP's
http://www.parsianet.com
Chupaka
Fri Apr 08, 2011 10:50 am
at first,
ip route print detail
because
ip route print
doesn't show routing-mark
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
arpadffy
Fri Apr 08, 2011 12:54 pm
[admin@MikroTik] > ip route print detail
Flags: X - disabled, A - active, D - dynamic, C - connect, S - static, r - rip, b - bgp, o - ospf, m - mme,
 0 ADS  dst-address=0.0.0.0/0 gateway=83.251.64.1 gateway-status=83.251.64.1 reachable ether1-gateway distance=1 scope=30
        target-scope=10 vrf-interface=ether1-gateway
 1 ADC  dst-address=83.251.64.0/20 pref-src=83.251.68.67 gateway=ether1-gateway gateway-status=ether1-gateway reachable
        distance=0 scope=10
 2 ADC  dst-address=146.172.65.24/32 pref-src=84.218.23.193 gateway=pppoe-out1 gateway-status=pppoe-out1 reachable distance=0
        scope=10
 3 ADC  dst-address=192.168.10.0/24 pref-src=192.168.10.1 gateway=ether2-local-master
        gateway-status=ether2-local-master reachable distance=0 scope=10
Unfortunately, I can not see any routing mark here either :( ... just in among rules.
Chupaka
Fri Apr 08, 2011 1:08 pm
it means, you don't have routing marks in your routes. marks cannot work if they don't exist =)
arpadffy
Fri Apr 08, 2011 1:34 pm
You are perfectly right... but what can I do more than define in rules. As you see I have done this
[admin@MikroTik] > ip route rule print detail
Is there anything that I missed?
Thank you.
Regards,
Z
Chupaka
Fri Apr 08, 2011 1:38 pm
what exactly do you want to do? if you have only one routing table (main) - you cannot use policy routing, because policy routing is usage of many routing tables with different gateways...
arpadffy
Fri Apr 08, 2011 2:08 pm
I have two uplinks: one fast (ether1-gateway) and one slow (pppoe-out1) that allows traffic on port 25.
I want to achieve that all traffic that come from LAN (ether2-local-master) go through pppoe-out1 and not the default route ether1-gateway (that does not allow traffic on port 25)
I do it as you can see above.
Thank you.
Regards,
Z
Chupaka
Fri Apr 08, 2011 2:21 pm
/ip route add gateway=pppoe-out1 routing-mark=smtp
and you may remove your routing rule - it's not used anywhere
arpadffy
Fri Apr 08, 2011 2:36 pm
THANK YOU VERY MUCH.
It works now... I just wonder how could it work earlier - indeed I have migrated from a RB750 to a RB450G - maybe I have missed this line.
Regards,
Z
Users browsing this forum: No registered users and 70 guests
