SQx
v.5.1 release
Sat Apr 09, 2011 11:09 am
Hello ,
I have routerboard g450 with v5.1, i have following problem, when i try :
Terminal
system routerboard> upgrage
Do you really want upgrade firmware?[y/n]
y
firmware upgraded succesfully, please reboot for changes take effect
After reboot - no effect!
MCP, CCNA, CCNP
normis
Re: v.5.1 release
Sat Apr 09, 2011 11:38 am
does "/system routerboard print" actually show any new routerboot version?
SQx
Re: v.5.1 release
Sat Apr 09, 2011 1:39 pm
please see attach.
MCP, CCNA, CCNP
napismizpravu
Re: v.5.1 release
Sat Apr 09, 2011 1:41 pm
still can't update RB433UAH ...
[admin@RB433UAH] > /system routerboard print
       routerboard: yes
             model: "433UAH"
     serial-number: "28050195xxFD"
  current-firmware: "2.27"
  upgrade-firmware: "2.29"
[admin@RB433UAH] > system routerboard up
Do you really want to upgrade firmware? [y/n]
y
firmware upgraded successfully, please reboot for changes to take effect!
       routerboard: yes
             model: "433UAH"
  current-firmware: "2.29"
[admin@RB433UAH] >
After the reboot routerboard without effect.
ditonet
Forum Veteran
Forum Veteran
Re: v.5.1 release
Sat Apr 09, 2011 1:51 pm
 /system routerboard settings
set force-backup-booter=no
then try to upgrade.
HTH,
Grzegorz | MTCNA, MTCRE, MTCSE | konsultacje MikroTik Warszawa
It is a book about a Spanish guy called Manual. You should read it. - Dilbert
napismizpravu
Re: v.5.1 release
Sat Apr 09, 2011 2:11 pm
HTH,
Good advice, the update is successful. :D
CPU frequency for the update to the 100 MHz and was followed by the:
system routerboard settings set cpu-frequency=680
USB flash drive is lost, the micro-sd OK, helped the interruption of power supply routerboard.
panteraboy
Re: v.5.1 release
Wed Apr 13, 2011 10:56 pm
why can not I access webfig interface?
RB750, RB433AH, RB2011RM
dssmiktik
Forum Veteran
Forum Veteran
Re: v.5.1 release
Thu Apr 14, 2011 10:03 pm
Webfig broke in v5.1 5.2 should be released to fix this bug.
Mikrotik, what changed in v5.1 webfig that broke it? Is there anywhere we might log this to let users know not to use v5.1?
Doug
normis
Re: v.5.1 release
Fri Apr 15, 2011 4:46 am
v5.2 will be released tomorrow. Sorry about that webfig problem.
adi55
Re: v.5.1 release
Fri Apr 15, 2011 5:16 am
HTH,
I followed your advice and I upgraded the firmware from 2.28 to 2.29.
But, with the new firmware, I can't log in winbox from MAC address (which I use by default). Actually I can connect only through IP address.
How can I resolve this problem?
Any suggestion?
yours,
reverged
Re: v.5.1 release
Fri Apr 15, 2011 5:20 am
RE: webfig problem
I'm not sure if this is the same error, but this breaks webfig in FF. It remains stuck at "loading".....
From firebug:
missing ; before statement
http://<ip>/webfig/engine.js
Line 1
Of course, Line 1 is the entire file....
normis
Re: v.5.1 release
Fri Apr 15, 2011 9:21 am
yes, as stated many times before, we know about this, and v5.2 will be released tomorrow, with the fix for this. of course there are other fixes there too :)
ditonet
Forum Veteran
Forum Veteran
Re: v.5.1 release
Fri Apr 15, 2011 12:44 pm
@adi55
Check your settings in '/ip neighbor', maybe discovery is disabled on local interfaces.
HTH,
petro25
Re: v.5.1 release
Fri Apr 15, 2011 1:29 pm
Incorrectly quality
honzam
Re: v.5.1 release
Fri Apr 15, 2011 3:07 pm
Normis-
Can we test 5.2 or tomorrow to have any plan to change build? Directory Share Mikrotik. Thanks
LAN, FTTx, Wireless. ISP operator
reverged
Re: v.5.1 release
Sat Apr 16, 2011 10:07 pm
I keep checking back and this post still says "tomorrow".
Is the unit of measure an Earth day or Venus day?
petro25
Re: v.5.1 release
Sun Apr 17, 2011 6:29 am
radio r52Hn rb433
It is malfunction of the equipment or an program problem??
THG
Re: v.5.1 release
Mon Apr 18, 2011 3:12 pm
Still waiting! :)
petst
Re: v.5.1 release
Mon Apr 18, 2011 7:52 pm
Everyone still waiting :D
honzam
Re: v.5.1 release
Mon Apr 18, 2011 8:59 pm
still nothing :(
janisk
Re: v.5.1 release
Wed Apr 20, 2011 12:52 pm
while testing 5.2 for release some more problems where found, so we are working on those and thus release of 5.2 is delayed.
suse
Re: v.5.1 release
Wed Apr 20, 2011 12:59 pm
demo2.mt.lv is on 5.2, if anyone wants to play with.at least from winbox, I know it is 5.2
exebug
Re: v.5.1 release
Wed Apr 20, 2011 5:35 pm
My RB450 runs 100% cpu all the time with 5.1
normis
Re: v.5.1 release
Thu Apr 21, 2011 7:32 am
open tool->profile and see what specifically causes this
falz
Re: v.5.1 release
Thu Apr 21, 2011 11:03 pm
I just ran into the 100% cpu issue. How it happened:
* Was logged into RB1100 w/ 5.1 via SSH.
* Was going to /ip neighbor discovery to check settings. In the middle of typing the command the SSH session became unresponsive.
* SSH'd in via another console, it authenticated immediately but the console took forever to display the MOTD (mikrotik logo in text). Never received an actual prompt
* Logged in via winbox, everything working fine, it shows 100% cpu. Even launching a terminal from within Winbox had the same issue- took forever to display MOTD, never gets to an actual shell.
I left it this way for about an hour, it never recovered. Rebooted it. Issue has not occured again yet. I will remain logged in via ssh to see if it reproduces. The device in question is barely doing any traffic and has a single IPSec tunnel:
Is there any way to manually kill connected users/shells? This may have cleared up the problem.
dssmiktik
Forum Veteran
Forum Veteran
Re: v.5.1 release
Fri Apr 22, 2011 3:17 am
Thank you for the update :) I would like to wait for upgrade v5.2 when it is fully ready, working, and stable.
Doug
eplejuz
Re: v.5.1 release
Tue Apr 26, 2011 5:26 pm
I still dun see 5.2
napismizpravu
support Alpha AWPCI085HU RouterOS v 5.x ?
Tue Apr 26, 2011 11:19 pm
Does not support Alpha AWPCI085HU miniPCI 500mW (Atheros AR5414, 802.11 a b g) in the RouterOS 5.x RB433UAH. Scan OK, connect: "failed connect, on 2452, authentication timeout". AP encrypted and unencrypted (R52H connect OK). RouterOS 4.3 works.
jadu
Re: v.5.1 release
Wed Apr 27, 2011 2:46 pm
I still dun see 5.2
Tomorrow has come ! :D
I will test the new 5.2 ASAP.
Don't give thanks, give karma instead!
SQx
Re: v.5.1 release
Wed Apr 27, 2011 10:42 pm
After upgrage firmware routerboard to 2.29, have problem this 5.2 release, i can not update this release. Routerboard 450g work only 8 volts, when use 24 volts all ports - shutdown, no signals.
How can i resolve my problem.
MCP, CCNA, CCNP
Users browsing this forum: filequit and 55 guests
