MUM Europe 2020
mcustance
3G USB problems RB433UAH
Thu Apr 14, 2011 12:03 pm
I am having all sorts of problems with this board. I have tried 2 different USB keys.
1st key ZTE MF112, resulted in USB port invalid errors and random reboots
2nd key Huawei E169 USB modem 19 times out of 20 they board doesnt pickup the device after a reboot. I can disconnect the key a 100 times, plug it back in and it wont see it - Also now seeing random reboots
Only time I can get it to pick it up on random occasions is a power off for 10+ min or doing a fimrware upgrade or downgrade.
I have tried firmware 5.1 and 4.17
Is there any way of getting this to work and remain stable? I cant afford to keep on buying these keys :)
alexspils
Re: 3G USB problems RB433UAH
Thu Apr 14, 2011 1:17 pm
did you tryed usb power reset feature?
mcustance
Thu Apr 14, 2011 1:23 pm
when I run that command it says it isnt supported on this hardware
awacenter
Fri Apr 29, 2011 11:35 am
I have the same issue with this routerboard : rb433UAH.
I tried with several Huaway 3G modems and ZTE modem. All hardware supported, I specifically checked.
I tried with routeros 4.17, later with 5.2 and 4.13. No successfully results.
Is it posible that rb433UAH routerboad has any issue?
awacenter
Fri Apr 29, 2011 12:18 pm
By the way,
[admin@MikroTik] /system resource usb> power-reset
ERROR: USB power reset not implemented on this hardware
I send the support.rif to be analysed.
pkelly1603
Mon May 09, 2011 7:07 pm
By the way,
I have the same problem. RB411U w/ RouterOS 4.17 and latest firmware (2.29)
ADTmaster
Sat Jul 16, 2011 3:43 am
Pease tell us if RB411 can support USB POWER OFF mode?
Users browsing this forum: ahmet32, jondavy, kpalagin, lw97, mbovenka, mkx, mrtrca and 146 guests
