MUM Europe 2020
wagnerdd
Winbox + Wine = Black Borders
Wed Apr 20, 2011 2:19 am
Hi, I am facing a strange problem that I do not know if you already have a solution or "work around".
When I open the Winbox through Wine (Linux) all buttons are a black border and the window are difficult to understand, attached is an example screen.
I've done tests with newer and older versions of Winbox.exe and Wine (1.2 and 1.3).
Someone could tell me anything?
Thank you in advance any help.
mrz
Re: Winbox + Wine = Black Borders
Wed Apr 20, 2011 2:12 pm
It looks like changed appearance of default theme. Open winecfg and check 'Desktop integration' tab
wagnerdd
Wed Apr 20, 2011 3:41 pm
I checked I do not have any customization or theme installed.
butche
Trainer
Trainer
Fri Apr 22, 2011 9:27 am
I am seeing this, too. At one time, there was a problem with the fonts (you need msttcorefonts installed). I have installed 2 versions of these fonts and still this problem persists. I just removed my .wine directory to ensure that my wine customizations were not causing this issue. I am using Fedora 14 (new install) with wine 1.3.17. I would be very happy to see any help on this front, as this is really a painful way to use winbox. I generally use CLI for my own routers, but I use winbox to "remember" customer passwords. PLEASE, if anyone has some ideas, I'm game to try anything.
Butch Evans
Mikrotik Certified Trainer
Mikrotik Certified Consultant
BLOG: blog.butchevans.com
http://store.wispgear.net/
butche
Trainer
Trainer
Tue May 10, 2011 10:00 am
I think I'm on the track to fixing this issue. When I debug wine as it is loading winbox, it is looking for (and not finding) these font files: vgaoem.fon,vgafix.fon,serife.fon
Anyone have an idea where I can find these?
Butch Evans
EMOziko
Tue May 10, 2011 11:40 am
There is no hope. Cus mikritik said: "winbox and the dude working perfect on wine and you dont need linux native versions". LOL
and other LOL for mikrotik cus they are using linux kernel for there software for free and they are not making linux native clients for this software.
We want new versions of The Dude!!!!!!!
bburley
Tue May 10, 2011 12:27 pm
You might find this interesting;
http://support.microsoft.com/kb/315338
Perhaps the other files are in there too.
bburley
Tue May 10, 2011 12:35 pm
This is even more interesting;
http://ubuntuforums.org/archive/index.p ... 32748.html
BladeforgerJanuary 21st, 2009, 07:38 PM
Well it appears I was looking at the wrong thing altogether. The fix was to alter a line in ~/.wine/system.reg.
It had some ridiculous number there and I changed it to 60 dpi just to be safe. here is what it looks like now:
[System\\CurrentControlSet\\Hardware Profiles\\Current\\Software\\Fonts] 1225516090
"FIXEDFON.FON"="vgafix.fon"
"FONTS.FON"="vgasys.fon"
"LogPixels"=dword:00000060
"OEMFONT.FON"="vgaoem.fon"
Much better, I hope this helps someone out there.:guitar:
It did help someone else out there... ME! Thanks. This helped me fix the problem of turning the screen resolution up way too high to see all of the screen... just as described in the original post.
SilverPotatoJanuary 22nd, 2009, 05:15 PM
This is easy!
If you have a separate boot for Windows (2K, XP, or Vista) you just copy the fonts from the C:\Windows\Fonts\ folder into your Wine's windows\fonts\ folder.
Simple as that.
butche
Trainer
Trainer
Tue May 10, 2011 10:01 pm
I don't need a native Linux version. I just need to find the proper fonts.
Butch Evans
butche
Trainer
Trainer
Tue May 10, 2011 10:06 pm
I've seen that one as well as the other one you mentioned. I don't have a windows xp (or windows anything for that matter) CD. I don't use Windows, so those are not an option. Thanks for the ideas and your search, though.
Butch Evans
maximan
Trainer
Trainer
Wed May 11, 2011 5:06 pm
I have the same issue. I install ubuntu 10.10 about 1 month ago and since it I have the black wine. I try to reinstall fonts, configuration of registry, themes and it don't work.
M.
MKE Solutions > Professional Support IT (Spanish / English)
FastNetMon / FNM Manager: DDoS Detection Tools.
janisk
Fri May 13, 2011 8:51 am
it is a long shot, but if you have Intel card you should try to upgrade your drivers. There are reports of different windows programs having these black artefacts in simple UI interface using wine on different flavours of Linux.
check if you are running xf86-video-intel 2.12.0 or newer if so, try to downgrade to 2.11.0
darkwarrior
Mon May 16, 2011 4:15 pm
Hello, i'm using Ubuntu 11.04 and for solve my problem I added to the registry of Wine:
[HKEY_CURRENT_USER\Software\Wine\X11 Driver]
"ClientSideWithRender"="N"
Create a file test.reg with this key, and on terminal:
regedit test.reg
My problem was solved.
maximan
Trainer
Trainer
Mon May 16, 2011 7:58 pm
regedit test.reg
Thanks!!! This was the solution. I give your karma.
M.
wagnerdd
Mon May 16, 2011 8:33 pm
Finally, many thanks to all friends, problems solved.
butche
Trainer
Trainer
Mon May 16, 2011 8:42 pm
I downgraded to Fedora 13, which uses the intel driver verion 2.11.0 and this solved my problem as well.
Butch Evans
butche
Trainer
Trainer
Mon May 16, 2011 8:46 pm
Awesome! Where in the world did you find this? I've googled for WEEKS!
Butch Evans
darkwarrior
Mon May 16, 2011 10:39 pm
I'm was searching for problem in winbox, but i've found in freedesktop.org forums.
A little lucky.
dschulz
Fri Jul 22, 2011 4:32 am
Finally!! :D :D I've been looking for a solution to this problem for a long time!
Thanks darkwarrior!!
jasperman
Wed May 28, 2014 6:22 pm
Old thread, I know, but I had a similar problem after upgrading to Ubuntu 14.04 and this workaround fixed it. Winbox fonts changed, text fields were incomplete, and text cursor was misplaced, so when I typed something, new text appeared in a different place than the cursor. Like this:
Petzl
Wed May 28, 2014 8:03 pm
Do you all know that you need to put a gateway in your fixed ip configuration in order to use mac discovery in wine ?
if you use dhcp there is no problem
Users browsing this forum: No registered users and 111 guests
