ejmerkel
SNMP problem after 5.2 upgrade
Thu Apr 28, 2011 5:01 pm
After upgrading 4 PC x86 boxes from 5.0rc7 to ROS 5.2, I noticed my cacti graphs stopped working.
I checked and rechecked all my SNMP settings and also notice I am no longer able to snmpwalk these devices. Below is the log output from one of the boxes when I try to snmpwalk it. Basically "snmpwalk -v2c -c MyCommunity IP_Address" just times out but obviously the x86 device is seeing the requests.
Is this a bug?
09:49:09 script,error
09:49:14 snmp packet from: 192.168.10.41 version: 0
09:49:14 snmp community: MyCommunity
09:49:14 snmp,debug get .1.3.6.1.2.1.2.2.1.1.9
09:49:14 snmp,debug grouping OIDs
09:49:14 snmp,debug oid >.1.9<
09:49:14 snmp,debug oid >.2.9<
09:49:14 snmp,debug oid >.3.9<
09:49:14 snmp,debug oid >.4.9<
09:49:14 snmp,debug oid >.5.9<
09:49:14 snmp,debug oid >.6.9<
09:49:14 snmp,debug oid >.7.9<
09:49:14 snmp,debug oid >.8.9<
09:49:14 snmp,debug oid >.9.9<
09:49:14 snmp,debug oid >.10.9<
09:49:14 snmp,debug oid >.11.9<
09:49:14 snmp,debug oid >.12.9<
09:49:14 snmp,debug oid >.13.9<
09:49:14 snmp,debug oid >.14.9<
09:49:14 snmp,debug oid >.15.9<
09:49:14 snmp,debug oid >.16.9<
09:49:14 snmp,debug oid >.17.9<
09:49:14 snmp,debug oid >.18.9<
09:49:14 snmp,debug oid >.19.9<
09:49:14 snmp,debug oid >.20.9<
09:49:14 snmp,debug oid >.21.9<
09:49:14 snmp,debug oid >.22.9<
09:49:22 snmp packet from: 192.168.10.41 version: 0
09:49:22 snmp community: MyCommunity
09:49:22 snmp,debug getnextgetbulk .1.3.6.1.2.1.25.3.3.1.2 reps:0 nonreps:0
09:49:22 snmp,debug getnextgetbulk .1.3.6.1.2.1.25.2.3.1.2 reps:0 nonreps:0
09:49:22 snmp,debug getnextgetbulk .1.3.6.1.2.1.25.3.3.1.2.1 reps:0 nonreps:0
09:49:22 snmp,debug getnextgetbulk .1.3.6.1.2.1.25.2.3.1.2.65536 reps:0 nonreps:0
09:49:22 snmp,debug getnextgetbulk .1.3.6.1.2.1.25.3.3.1.2.2 reps:0 nonreps:0
09:49:22 snmp,debug getnextgetbulk .1.3.6.1.2.1.25.2.3.1.2.131077 reps:0 nonreps:0
09:49:22 snmp,debug get .1.3.6.1.2.1.25.2.3.1.6.131077
09:49:22 snmp,debug get .1.3.6.1.2.1.25.2.3.1.5.131077
09:50:14 snmp packet from: 192.168.10.41 version: 0
09:50:14 snmp community: MyCommunity
09:50:14 snmp,debug get .1.3.6.1.2.1.2.2.1.1.9
09:50:14 snmp,debug grouping OIDs
09:50:14 snmp,debug oid >.1.9<
09:50:14 snmp,debug oid >.2.9<
09:50:14 snmp,debug oid >.3.9<
09:50:14 snmp,debug oid >.4.9<
09:50:14 snmp,debug oid >.5.9<
09:50:14 snmp,debug oid >.6.9<
09:50:14 snmp,debug oid >.7.9<
09:50:14 snmp,debug oid >.8.9<
09:50:14 snmp,debug oid >.9.9<
09:50:14 snmp,debug oid >.10.9<
09:50:14 snmp,debug oid >.11.9<
09:50:14 snmp,debug oid >.12.9<
09:50:14 snmp,debug oid >.13.9<
09:50:14 snmp,debug oid >.14.9<
09:50:14 snmp,debug oid >.15.9<
09:50:14 snmp,debug oid >.16.9<
09:50:14 snmp,debug oid >.17.9<
09:50:14 snmp,debug oid >.18.9<
09:50:14 snmp,debug oid >.19.9<
09:50:14 snmp,debug oid >.20.9<
09:50:14 snmp,debug oid >.21.9<
09:50:14 snmp,debug oid >.22.9<
09:50:18 snmp packet from: 192.168.10.41 version: 0
09:50:18 snmp community: MyCommunity
09:50:18 snmp,debug get .1.3.6.1.4.1.14988.1.1.1.1.1.7.10
09:50:18 snmp,debug error: no such name
09:50:22 snmp packet from: 192.168.10.41 version: 0
09:50:22 snmp community: MyCommunity
09:50:22 snmp,debug getnextgetbulk .1.3.6.1.2.1.25.3.3.1.2 reps:0 nonreps:0
09:50:22 snmp,debug get .1.3.6.1.2.1.25.2.3.1.6.131077
09:50:22 snmp,debug get .1.3.6.1.2.1.25.2.3.1.5.131077
09:50:22 snmp,debug getnextgetbulk .1.3.6.1.2.1.25.3.3.1.2.1 reps:0 nonreps:0
09:50:22 snmp,debug getnextgetbulk .1.3.6.1.2.1.25.3.3.1.2.2 reps:0 nonreps:0
NoXy
Re: SNMP problem after 5.2 upgrade
Mon May 02, 2011 4:19 pm
I've same problem, 5.2 PPC. Since upgrade I've no SNMP :(
normis
Tue May 03, 2011 11:16 am
please also contact support with detailed problem description and supout.rif file made at the time of the problem
janisk
Tue May 03, 2011 11:31 am
could any of you give some more details about the problem?
i tried on PPC and x86
$ snmpwalk -c public -v 1 mt
with success
ejmerkel
Tue May 03, 2011 3:11 pm
I have submitted a ticket to support. I can report that I have two other x86 units that were upgraded from 5.1 to 5.2 and SNMP seems to be working. However the ones that were upgraded from 5.0rc7 to 5.2 directly seem to be having the issue. Perhaps the configuration got corrupted during the upgrade? It appears to me like there is an extra "/snmp" section to my config. See the last part of the config that I can't rid of. I've tried removing all SNMP settings and re-adding them.
/snmp> export
/snmp
set contact="MetaLINK Technologies" enabled=yes engine-id="" location="Sherwood Tower" \
    trap-community=XXXXX trap-target=0.0.0.0 trap-version=1
/snmp community
add address=10.11.0.0/24 authentication-password="" authentication-protocol=MD5 \
    encryption-password="" encryption-protocol=DES name=XXXXX read-access=yes security=none \
    write-access=no
/snmp
Eising
Tue May 03, 2011 5:13 pm
I have the same issue and I'm talking with support at the moment about it.
SNMP disappeared after upgrade from 4.6 to either 5.1 or 5.2.
The road to hell is paved with good intentions.
ilius168
Mon May 09, 2011 5:09 pm
reported about snmp since 5.0, snmp v1 doesn't work but snmp v2 does. some other snmp such as available disk space not working neither in both version........
BUGS??
rotten777
Tue May 10, 2011 3:48 am
nevermind fixed it with a secure snmp setup... weird
ElectricCat
Tue May 10, 2011 10:39 am
I've got the problem that the SNMP OID 1.3.6.1.4.1.14988.1.1.1.4.0 (mtxrWlRtabEntryCount) does not return what it intended for - it tells me that I have 0 registration table entries, while there are 6 clients registered there. It began when I upgraded my RB600's RouterOS from 4.16 to 5.2. Rolling it back solved the problem, but I want to use 5.2 there :)
avm2nn
Tue May 10, 2011 11:17 am
Begining with v5.x there's one difference (critical for us) in the way how mtik snmp server process the GetNextRequest in case when OID is not full.
In v3.x and 4.x to get a signal level of some client from RegTable we could use "short" form of GetNextRequest (without pointing OID of wlan interface at the end) and got answer about that signal level of that client (with added number of wlan interface at the end ..)
IP 10.52.0.1.58435 > 10.52.0.20.161: GetNextRequest(40) .1.3.6.1.4.1.14988.1.1.1.2.1.3.0.12.66.98.71.136[|snmp]
IP 10.52.0.20.161 > 10.52.0.1.58435: GetResponse(42) .1.3.6.1.4.1.14988.1.1.1.2.1.3.0.12.66.98.71.136.4=[|snmp]
(If there is no such client in RegTable at that moment, it is offline for ex., we checked it parsing part of OID in snmp answer ..)
Since 5.x - if GetNextRequest does not contain oid of interface number at the end, mtik snmp server reply is "noSuchName":
IP 10.52.0.1.49767 > 10.52.0.19.161: GetNextRequest(40) .1.3.6.1.4.1.14988.1.1.1.2.1.3.0.12.66.102.192.92[|snmp]
IP 10.52.0.19.161 > 10.52.0.1.49767: GetResponse(40) noSuchName@1 .1.3.6.1.4.1.14988.1.1.1.2.1.3.0.12.66.102.192.92=[|snmp]
But this OID (with .4 at the end) exist in the RegTable:
snmpwalk -v1 -c test 10.52.0.19 SNMPv2-SMI::enterprises.14988.1.1.1.2.1.3
...output ommited...
SNMPv2-SMI::enterprises.14988.1.1.1.2.1.3.0.12.66.102.192.92.4 = INTEGER: -5
Is that behaviour of snmp server ROS 5.x bug or feature ? ))
avm2nn
Fri May 13, 2011 8:44 am
Anybody here? Any support? :)
ElectricCat
Fri May 13, 2011 9:18 am
I think, we have to call the support team, not forum :) I'll create a ticket about 0 wireless clients in registration table
UPD: Done. 2011051366000199
sergejs
Fri May 13, 2011 1:52 pm
Hey guys, thank you very much for your reports!
Finally we were able to trace the problem, issue will be fixed at RouterOS v5.3.
felipesilveira
Sat May 14, 2011 1:56 am
Hello sergejs
when the 5.3 release will be available? I need this because I have to check PPPoE connections (I use it via SNMP)
I have just bought a 5.2 license (today) and I'm not comfortable to downgrade to 4.17 version
Thanks in advance!
Chupaka
Sat May 14, 2011 11:38 am
write to support@ - they (most likely) will give you test version of 5.3
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
jami
Thu May 19, 2011 1:43 am
I have a problem with cacti graph from queue simple. Sometimes the graph didn't show anything (0). When I tried query again in cacti device, the graph show normal (after graph show spike until 20-50mbps, although the real traffic just 500kbps). But after couple hours, back show nothing...
I need upgrade to version 5.x because I need to limit IPv6 with queue simple. Thanks.
jonatasmv
Fri May 27, 2011 8:59 pm
The problem has a solution? I did upgrade to 5.4 today and I still have incomplete data collections of simple queues. What it is necessary to provide support?
ElectricCat
Sat May 28, 2011 10:59 am
Did you wrote to MikroTik support team? :) Send them the description of your problem and attach the supout.rif file made just before you sent the email
chipus
Thu Oct 27, 2011 1:43 pm
Router OS v. 5.7
problem still here.
My fix for this problem use this option:
-Cc Do not check whether the returned OIDs are increasing. Some agents (LaserJets are an example) return OIDs out of order, but
can complete the walk anyway. Other agents return OIDs that are out of order and can cause snmpwalk to loop indefinitely. By
default, snmpwalk tries to detect this behavior and warns you when it hits an agent acting illegally. Use -Cc to turn off
this check.
joko96pw
Fri Dec 16, 2011 6:17 am
SNMP still has problem in v5.7 , i'm using RB1000 . The graph will appeared when i stays open for winbox queue windows. As soon as winbox closed, graph will not show again . Any workaround guys ?
Users browsing this forum: Bokous, dtv2, Semrush [Bot], thenexontv, w1552270 and 46 guests
