reeeq
ZeroConfig not working if there is no ip gw defined
Tue May 10, 2011 8:31 pm
Just find out, that the zero config / universal NAT feature won't work when there's no ip gateway defined on client's computer
(there is ip address and netmask on client's but no ip gateway, and no dns ip defined).
Is there any solution for this ?
Thank you
Egate
Long time Member
Long time Member
Re: ZeroConfig not working if there is no ip gw defined
Sun May 15, 2011 5:38 pm
Your PC will have to know, where to send data that is not on the local network, gateway. You could make use of DHCP, this way your clients PC is set on auto detect and you give it all the nat, gateway, ip info needed.
Happy days. :-)
Users browsing this forum: RonJohn63 and 191 guests
