harmen
RB450G hangs after upgrade to OS 5.4
Mon May 30, 2011 7:39 pm
After upgrading from OS 4.13 to OS 5.4 on RB450G hangs after a few minutes. This problem was not the RB750G and RB411AH ....
phuang3
Re: RB450G hangs after upgrade to OS 5.4
Tue May 31, 2011 4:53 pm
Well, my RB450G doesn't have this problem after upgrading to v5.4
kirshteins
Wed Jun 01, 2011 9:46 am
Is there any output on serial console? Please generate and send supout.rif file to support@mikrotik.com
http://wiki.mikrotik.com/wiki/Manual:Su ... utput_File
ibeeby
Thu Jun 02, 2011 1:22 am
I have an RB433 and a 493 that both perform uselessly after upgrade to 5.4 - 100% CPU and essentially no operation - with winbox all devices appear to be absent - wireless will accept a connection on the 433 but then drops it. Basic ip routing appears to be working but very poor and laggardly.
Any suggestions?
On the 493, works fine until it receives an OVPN connect request when the 100% cpu starts - so after about 20s after re-boot it is useless.
How do I back out back to 4.16?
Regards
Ian
suse
Thu Jun 02, 2011 4:57 am
Any suggestions?
Regards
Ian
upload 4.16 npk, system package downgrade , then reboot it.
ibeeby
Thu Jun 02, 2011 7:39 pm
Yup - that seems to have worked - many thanks.
I have grave concerns about 5.4 if it is going to run my RB433 router flat out - normal CPU occupancy is around 2%.
Any thoughts as to what the issue is?
Cheers
Ian
Users browsing this forum: No registered users and 51 guests
