MUM Europe 2020
HellMind
Configure bootloader without a serial cable
Tue Jun 07, 2011 9:30 pm
Is there a way to configure the bootloader without using the serial port?
fewi
Re: Configure bootloader without a serial cable
Tue Jun 07, 2011 10:17 pm
[admin@router] /system routerboard settings> pri
            baud-rate: 115200
           boot-delay: 2s
          boot-device: nand-if-fail-then-ethernet
       enter-setup-on: any-key
        cpu-frequency: 1333MHz
        boot-protocol: bootp
  enable-jumper-reset: yes
  force-backup-booter: no
          silent-boot: no
[admin@router] /system routerboard settings> set boot-device=
ethernet  flash-boot  flash-boot-once-then-nand  nand-if-fail-then-ethernet  nand-only  try-ethernet-once-then-nand
[admin@router]
Specific answers require specific questions. When in doubt, post the output of "/ip address print detail", "/ip route print detail", "/interface print detail", "/ip firewall export", and an accurate network diagram.
HellMind
Wed Jun 08, 2011 3:35 am
Thank you very much,
I didnt found anything googling on in wiki :(
HellMind
Wed Jun 08, 2011 3:48 am
When I reboot it goes back to
Something wrong
HellMind
Wed Jun 08, 2011 11:24 pm
I select ethernet and now it works fine
HellMind
Wed Jun 15, 2011 9:33 am
Is there another way to restore the bootloader default config, like pressing the reset button while is powering up or something?
Users browsing this forum: No registered users and 66 guests
